Have you installed rear speakers on a G6 Civic Sedan?
Old May 17, 2001 | 08:45 PM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Have you installed rear speakers on a G6 Civic Sedan?
https://honda-tech.com/zerothread?id=39542
Old May 24, 2001 | 08:24 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Re: Have you installed rear speakers on a G6 Civic Sedan? (GoLowDrew)
I found it. It's really in strange place where the bolt is. It's in a different angle from what the Crutchfield instructions said it would be. Stick your fingers in between the bottom seat cushion and side bolster, with the palm side in. Then curl your fingers up and there is is!. It's just like ....... well, you know
If would be best to best to get someone to help because the space is very tight to pry open, and may hard to get to the bolt with the socket wrench. I have not done it yet, but I can already see a problems with either the bolt coming off after you untighten it and fall deep in there, or the socket coming off the wrench as you pull out from there.
I'm ready for my speaker installation. Finally! Now I just have to buy the speakers.
mondo375
Jun 27, 2007 05:57 AM
outofstock
May 17, 2007 07:31 AM
MeanGreenEG9
Oct 27, 2002 10:42 AM
MeanGreenEG9
Sep 18, 2002 04:24 PM
