Throwout / Pivot Bearing Replacement.
When replacing the clutch and flywheel I was told to change the throwout bearing, however, the pivot bearing was not as important to replace.... I would like to replace both.... the R have 53,000 km's on her - 3 years old.
Any sugeestions?
Thanks.
Any sugeestions?
Thanks.
Any sugeestions?
Thanks.
Any sugeestions?
Thanks.
bearings = wear item for me
[Modified by Soup ****, 6:16 AM 1/24/2003]
Only 53K and your replacing the clutch already? Seems quite fast to replace unless your changing for a performance clutch.
When you do change it, i always recommend changing the throw-out and pilot bearing as well as re-surfacing the flywheel. Don't forget to grease the shaft for the throw-out bearing if your doing it yourself.
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
you seemed to have answered your own question. IF you want to replace it, replace it. even the throwout bearing isnt a "mandatory" thing to replace w/ the clutch, but its recommended.
seriously though, the throwout bearing and pilot bearing are cheap, and they should be replaced everytime the clutch is replaced. that would suck to install a clutch and hear the whine of a throwout bearing 5,000 miles later.....
thanks guys.... I am replacing the stock components with a kusk loc clutch, act extr. pressure plate and Toda FW... as well the JDM FD is also going in...
A FD install, is this mucho complicato?
OMG! a nice response from soup ****? is this a sign the end of the world is near?
No really.. I'd like to know
i might be wrong, but wheres is a pivot bearing on integra? most clutch kits for integra will include release bearing which a good idea to replace if taking transmission out..
Any sugeestions?
Thanks.
Any sugeestions?
Thanks.
B series have a pilot bearing, H series do not. The bearing is on the back side of the flywheel.
[Modified by GZR4DR, 1:55 AM 1/26/2003]
