what could be causing this??
ok every couple days i have to take my front tires off and put them back on, my steering wheel gets really loose and the steering seems to get really bad after a few days i cant figure out what it is, the lugs arent lose when i take them off either,,, the car is a 90dx wit 89 si rims, 3 inch drop on eibachs that are cut, and totiko blues.... ne help
What does taking your tires off and on do?
Try this. Jack the car up so the tire is an inch or two off the road. Then put a large pry bar or crowbar under the tire. Lift up and down on the bar and see where the play is coming from (upper control arm bushings or lower ball joint. Then grab the tire and jerk it left and right to check the play in the tie rod ends. Good luck and tell us what you find.
apbtwhiskey
21
Sep 16, 2013 05:27 AM
The Bster
Dec 21, 2007 09:44 AM
incognito E46
Sep 29, 2005 05:23 PM
