Will 90' integra springs & shocks work on 91' crx?
Just wondering if koni yellows and ground controls from a 90' teg will fit on 91' crx. If so any modifications have to be done? Thanks for the help.
They will physically bolt on at the top and bottom but the '90-93 Integra front and rear shocks are much longer than the CRX shocks. Don't do it unless you want the car to sit silly high. If you use the threading and put the perches at the botton, you still probably won't get low enough but you'll bottom the shocks out. CRX, especially the fronts, are bout as short as they get and that Integra is quite long.
my friend has CRX neuspeed springs on his integra. They lower a CRX about 2" and his integra like 3" it is slammed. mad tuck.
i put some aftermarket front shocks from a 93 civic coupe ex on my 88 crx si are they taller too?
94LS_allmota
Aug 18, 2005 07:37 AM
