koni install on RSX?
a friend of mine put some 2001 civic konis on his type S. i spoke with koni and they mentioned that they may fit right but they are a totally different shock than will be designed for the rsx.
you place the ****, the one that came with the rear struts, ontop of the strut (clearence is very tight) and turn the adjuster...the front adjuster **** has a longer shaft which won't work on the rear...
if it still won't fit, just pull the little plastic thing out from the center of the adjuster **** and cut it shorter and reinstall...that's what i did to give myself extra clearence...late
Thanks!
thanks to Jonathan too
Agent_Samz
Apr 27, 2010 10:26 AM
Desperado
10
Jan 20, 2008 12:33 AM
