brake master cylinder question
Old Jan 23, 2003 | 05:22 PM
sitrucjr's Avatar
Default brake master cylinder question
heres the deal,, my buddies car slowly leaks brake fluid around his drivers side tires,,both of them,,,he took it to a mechanic and the mechanic told him that its the master cylinder,,does that sound right to you guys?
Old Jan 23, 2003 | 05:25 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: brake master cylinder question (sitrucjr)
<U>that </U> doesnt sound right to me.
no...really, it sounds like the lines are leaking?maybe?
[Modified by fastcrxsi90, 9:26 PM 1/23/2003]
Old Jan 23, 2003 | 05:57 PM
sitrucjr's Avatar
Default Re: brake master cylinder question (fastcrxsi90)
thats what i think too
Old Jan 23, 2003 | 06:02 PM
ViperRedCRX's Avatar
lines, or caliper/wheel cylinder are the only things that could be leaking at the tires
Old Jan 24, 2003 | 01:16 PM
Wes V's Avatar
Default Re: brake master cylinder question (CRX-T)
The mechanic is crazy! How would a leaking master cylinder get fluid to the drivers side rear tire?!?!
It sounds like there are two different leaks.
Wes.
Old Jan 24, 2003 | 05:05 PM
Drumwurks's Avatar
Default Re: brake master cylinder question (Wes V)
If the fluid is making it to the tire... that must mean there is a lot of fluid coming out. I wouldn't drive that car.
Check out the calipers and the flex lines that go to them. If it's a drum rear, pull the drum and inspect the lines going in there.
If it's only leaking on one side, and the leak is occuring at the wheels... it's not gonna be your master cylinder.
Unless the mechanic meant the rear drum cylinder. But that wouldn't explain the front leak.
PhilE2212
Suspension & Brakes
Nov 7, 2012 10:08 AM
PhilE2212
Nov 2, 2012 08:26 PM
eh9deux
17
Jun 13, 2011 07:33 AM
patrickstar
Apr 4, 2009 07:57 PM
bb4socal
Sep 4, 2006 09:51 PM
