What do you think of my setup?
Old Jan 23, 2003 | 02:33 PM
YellowR2000x2's Avatar
Default What do you think of my setup?
So the engines in the car...all im waiting on is my TB and header...heres my setup:
importbuilders 2l GSR block running 12:1 CR
portflow P&P type R head with complete vavletrain and skunk2 stage 2 cams
comptech icebox
toda header, carsound cat, and Greddy EVO exhaust
Hondata s100 with RC 440cc injectors
AEM FPR, fuel rail and B&M FP guage
CM stage 4 clutch with CM flywheel
Skunk2 cam gears
So what do you guys think? what do you think ill be puttin down? anyone see any weak links in the setup? just wondering what ya'll think of it.
Old Jan 23, 2003 | 03:23 PM
JDMITR222's Avatar
Default Re: What do you think of my setup? (YellowR2000x2)
I like it
Old Jan 24, 2003 | 10:06 AM
Default Re: What do you think of my setup? (JDMITR222)
i like it too!
Old Jan 24, 2003 | 10:25 AM
CHRIS 1.8's Avatar
What kind of valvetrain are you going to use with your Skunk2 Stage II cams?
Old Jan 24, 2003 | 10:29 AM
RTW DC2R's Avatar
Id say go with a different exhaust if anything. Not sure how great the GReddy is compared to other stuff out there. Tough to say how much power you will be making, but I know someone with a LS head/2L CRV bottom end, ITR cams, basic bolt ons, and interior gutted and he was running mid to high 13's in a gutted LS teg. not sure how much power he is actually making though. Good luck and tuning is key
Old Jan 24, 2003 | 11:58 AM
b0wti's Avatar
Default Re: What do you think of my setup? (RTW DC2)
with that kind of a setup, i might go for a custom exhaust, Evo is a great sound though..
[Modified by b0wti, 8:59 PM 1/24/2003]
Old Jan 24, 2003 | 12:08 PM
hooptie157's Avatar
Default Re: What do you think of my setup? (b0wti)
say Bye bye to da carsound. It with destroy itself under the extreme conidtions of your motor and I'd look into a different exhaust but other than that looking good
Old Jan 24, 2003 | 12:26 PM
JUNGSR's Avatar
Default Re: What do you think of my setup? (hooptie157)
nice set up but i think the injectors are way too big
Old Jan 24, 2003 | 12:30 PM
JUNGSR's Avatar
Default Re: What do you think of my setup? (JUNGSR)
what kind ot tranny are you running in there that plays a big role in your 1/4 mile time if it's the gsr better get a lsd
Old Jan 24, 2003 | 12:42 PM
Eva01's Avatar
I agree! The greddy evo is 2.36mm which would create a bottleneck when going from the Toda 2.5" collector to the 2.36 of the Greddy. I would stay with 2.5" throughout the entire exhaust system for maximum gains.
Old Jan 24, 2003 | 06:11 PM
Default Re: What do you think of my setup? (gaijin22)
yea, it'll be on pump gas w/ alot of tuning.
also ill be using my Type R tranny so ill at least have an LSD
my valvetrian is a portflow
yea, that what i was thinking of with the exhaust, anyone know of a 2.5" b-pipe that will bolt up to the EVO axle back?
and also why do you say the cat will go bye bye? ive heard a few people running the carsound with the 2l setup? which cat should i run on it then?
[Modified by YellowR2000x2, 6:24 PM 1/25/2003]
Old Jan 25, 2003 | 09:28 AM
what about the Type-one B-pipe? does anyone know if that bolts up to the EVO axle back? after everythings on there, ill let you guys know what i dyno at..
Eg6DR
30
Mar 12, 2008 05:08 PM
spooledex
Dec 4, 2006 02:42 PM
YellowR2000x2
Jun 21, 2003 10:03 PM
H22coupe
May 19, 2003 10:33 PM
trillo
Apr 25, 2002 10:11 AM
