**SOHC N/A guys - Represent yourself**
Old Jan 23, 2003 | 02:24 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default **SOHC N/A guys - Represent yourself**
I'm building my B20vtec, but I don't want to get rid of my SOHC vtec because I know the potential it has. Parts are cheap, and when swapping it into a light car such as a CRX, it can rip.
I want all you single cam guys who have "built" your D-series N/A to represent and list what mods you got and what are your dyno/quarter mile numbers.
Here's what I plan to do with the D-Series:
Into 88-91 CRX
D16Y8 Head w/IM
D16Y7 Block
B16a TB
D16A6 Pistons (11:1 CR after all said and done)
LIghtened FW
I/H/E
Redline @ 8K and Vtec activation @ 5K
Think this setup will hit anywhere near 150whp? Think it'll do mid to low 14's?
*You FI guys don't count, but feel free to post*
Old Jan 23, 2003 | 02:35 PM
Spade's Avatar
Default Re: **SOHC N/A guys - Represent yourself** (GapxGuy)
You'll need a cam to put out any power above 7200.
Old Jan 23, 2003 | 02:41 PM
kyle h.'s Avatar
what about us guys that dont have a running D?
needs to be put back together yet. going to put a cheap turbo setup on it and run it around town for a daily driver. N/A would be cool if i had money.
[Modified by kyle h., 11:43 PM 1/23/2003]
Old Jan 23, 2003 | 04:08 PM
altoid's Avatar
Default Re: **SOHC N/A guys - Represent yourself** (kyle h.)
My sohc zc is still stock but i've got my list put together for when i get everything i'll put it in here it is:
Exospeed Race Cam (should arrive next week)
Upgraded Valve Springs from somewhere
*Enlarged Valves
Ported Head
CTR or d16a1 pistons
Upgraded rod bolts
upgraded head studs
Y8 ported intake manifold
2.5" exhaust piping
* I may or may not go with that, im still deciding
I believe thats about it, should take a while i'd say, but once its all done i'll have a sweet ride.
Old Jan 23, 2003 | 04:16 PM
Ek-CoolGuy's Avatar
Default Re: **SOHC N/A guys - Represent yourself** (altoid)
ctrs arent gonna fit buddy. unless you got 81/81.25mm cylinders
Old Jan 23, 2003 | 04:22 PM
ExospeedAMcrx's Avatar
*Enlarged Valves
2.5" exhaust piping
I dont think you should increase the valve size. the stock size will flow enough for what you are planning to do. honestly, the main problem that we encounter with the SOHC and even the DOHC setups are peoples, exhaust setup. A good brand like HKS, GREDDY will have a good efficient free flowing exhaust. the ones that cant dip that kind of money go for the muffler shop bent piping, which alot of times makes a great diff from a mandrel bent one. we did a sr909 cam in a 89hb Si, everything stock except for muffler, intake and header.
the restriction was so bad on the muffler shop done piping, especially the header to the catalytic back to the exh piping, that when we told him to change the piping to our specs, it made so much diff on the whole powerband.
...just a FYI: alot of people dont take that much time into researching on their exh setups.
oh and 2.25" is good enough for mildly modif setups.
valvetrain, we usually dont sell them separtely.. only comes with our head packages. but they are priced around $330set.
Old Jan 23, 2003 | 04:36 PM
altoid's Avatar
Default Re: **SOHC N/A guys - Represent yourself** (Ek-CoolGuy)
is that so? I suppose the ctr has a wicked odd stroke (well compared to the a6), nothing is finalized, ideas that'll be worked upon, thanks for the info, i'd hate to have pistons 10mm too big, i'd shoot myself
Old Jan 23, 2003 | 06:41 PM
87sivtec's Avatar
You should be easily into the 14's with slicks and a good clutch. Just watch the diff's in the tranny's. Preload the clutch slightly on launch with a 7000+ rpm launch and you should get very quick times. A friend of mine has a 93 si hatch with the engine unopened and with I/H/E and Fields VTEC controller. With slicks he is running in the 14's. On nitrous he has hit a 13.6 and then blew the diff.
(wasn't preloading the clutch- just 7500 rpm side step!!)
Good luck to ya.
Old Jan 23, 2003 | 07:10 PM
eg6ajk's Avatar
I went b-series. then back to d-series. then bug bit again b-series. then tommorw hopefully d-series again. this time with ZC sohc vtec.
LSD tranny is ready, flywheel, clutch and so on...to come crower II and few other goodies.
Old Jan 23, 2003 | 07:26 PM
kentucky accord's Avatar
Default Re: **SOHC N/A guys - Represent yourself** (eg6ajk)
i run the big block SOHC...f22..... here is a link to my car.
http://hometown.aol.com/conaire/index.html
Old Jan 23, 2003 | 07:36 PM
GapxGuy's Avatar
Default Re: **SOHC N/A guys - Represent yourself** (kentucky accord)
eg6ajk, again that is one sweet looking motor. What paint did you use to paint the valve cover? Was it the paint for summit racing? Are you gonna keep it stock compression? Post some numbers and keep us posted.
LOL...I did just say SOHC didn't I?
Old Jan 24, 2003 | 10:09 AM
GapxGuy's Avatar
Anyone else?
Old Jan 24, 2003 | 10:48 AM
yeah, i didnt know it was meant for just d16 guys. although, i did notice that the thread was primarily d series motors, i thought i would just throw mine in there.
Old Jan 24, 2003 | 01:29 PM
MEANB18's Avatar
Before I did my swap I had the D16Z6 in my civic EX. I read all over that GUDE makes the best stuff for a single cam honda, so I tried it out, and bought the bullfrog cam and the ECU program to match it. The difference was pretty significant, but I would suggest raising VTEC point by quite a bit, it REALLY bogs down hitting vtec. I would also invest in the ZC cable tranny, if you are going all motor the stock D16 gearing is really long, you drop out of vtec after every shift... Even if you took your car to 9200 rpms where the Gude ecu goes to. Hope that helps, with just that stuff and basic I/H/E you can hit mid to high 14's.
Old Jan 24, 2003 | 06:19 PM
pornstarSR's Avatar
well i dont think i count because im goin turbo but i love the SOHC....
Motor D16y7
ported polished head
portmatch intake and exhasut manifolds
ferrea vavles
custom vavle springs
custom cam grind
endyne roller wave pistons 9.5:1 comp
pauter rods
ported block(to clean up oil galleries and coolant galleries)
micropolished crank
cryogenically treated crank, rocker arms, block, head
balanced and blueprinted rotating assembly
thermal coated everything(swain coatings)
jun ultralight cromoly flywheel
clutchmasters stage 4
i was messing around with my friend in his 98 type R, and i kept up with him....but i was at 8 degrees timing..havnet played since i raised the timing
some stuff i may have left out....sig has a link to the build up
[Modified by pornstarSR, 3:20 AM 1/25/2003]
Old Jan 24, 2003 | 06:36 PM
2000CX's Avatar
Default Re: **SOHC N/A guys - Represent yourself** (pornstarSR)
oh man...i think i just found hope for my y7?!?! holy f!#@...how much did that set you back? what are the time slips looking like? whp?
Old Jan 26, 2003 | 02:28 PM
altoid's Avatar
Default Re: **SOHC N/A guys - Represent yourself** (2000CX)
everyone keep representing i like to see what kind of things you guys have done to your sohcs, its a refreshing change of pace
Old Jan 26, 2003 | 03:17 PM
All_Lag's Avatar
D16y8
I/E/H
High Flow Cat
Gude Racing Head Package coming in March
Old Jan 26, 2003 | 03:20 PM
All_Lag's Avatar
How Much WHP are you putting down PornstarSR?
Old Jan 26, 2003 | 08:11 PM
careawholelot's Avatar
Default Re: **SOHC N/A guys - Represent yourself** (SlowSOHC)
d16z6 in 94 cx
aem short ram
rs*r exhaust
1000 lbs rear springs
raced 94 dx hatch with gsr
aem cai
apexi n1 exhaust
qaiffe(sp?) lsd
i had his *** off the line but right when i shifted into 4 gear he blew buy me and smote me, i just hate how i'll shift at 7200-7400 and then it goes down to 3000-3500 rpm and feels slow as **** tell i'm back in vtec thats what gets me
i'm looking to go b20 turbo, but while i'm doing that i want to get the gude head package also in the summer time for my z6.
just wanted to say i got love for the sohc they can also give the dohc a run for there money.
Old Jan 26, 2003 | 10:32 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: **SOHC N/A guys - Represent yourself** (careawholelot)
Here's what I have so far...
D16Z6
milled head .020
port/polished/knocked down valve guides
3 angle valve job
ZEX street strip cam
I/E with sticj 4-2-1
Waiting to be installed:
AEM cam gear
Crower valve springs
Z6 block with A6 pistons
shot peened Z6 rods
DC header
new OEM clutch, possibly ACT or Clutchmasters
New tranny, or rebuild my synchros
[Modified by Emerica, 11:33 PM 1/26/2003]
Old Jan 27, 2003 | 02:13 PM
pornstarSR's Avatar
well i know im gone get flamed for this(probably not from you guys) i spent about $10,000 on everything
$7000 for engine
$3000 for turbo stuff (the turbo by itself was $1400)and i still have to make all the piping
when you want to be different it aint cheap....but its kind of fun
but the reason i did it is becasue all i see is Swap this Swap that.....you want an ultimate sleeper, Pop your hood and show them a Single Cam....thats the best reward ever......blowing the doors off an integra or an SI and the they ask"what do you got" ohh its just a SOHC NON-VTEC....they get kind of mad thinking im lieing....
as far as timeslips i havent gotten to the track yet....since SB is kind of far from LACR....soo and i have been working on a few different engines for friends....DAMN LS/vtecs....
as far as WHP. im shooting for 350-400, the motor guy built the motor to reach that with reasonable boost....9-14lbs.....but we will see....
Old Jan 27, 2003 | 02:17 PM
pornstarSR's Avatar
also something to tease the SOHC boys i was doing researcha nd im sure some of you know this already but...
Sohc bore and stroke - 75mm bore - 90mm stroke
LS/vtec bore and stroke - 81-84mm bore - 89mm stroke
hmmmm now i just have to figure out the stroke of the crank and see if its on par.....and maybe all you guys out there doing mini-me swaps have already figured this its could be a Baby LS/VTEC
ohh and this is a line i tell everyone, dont underestimate the Single Cam
[Modified by pornstarSR, 11:19 PM 1/27/2003]
Old Jan 27, 2003 | 10:57 PM
GapxGuy's Avatar
Default Re: **SOHC N/A guys - Represent yourself** (Emerica)
D16Z6
milled head .020
3 angle valve job
AEM cam gear
shot peened Z6 rods
DC header
Now that's what I wanna do. I'm (kinda) trying to make a SOHC version of the B16B.
Old Jan 28, 2003 | 07:17 AM
crxfanatic's Avatar
New User
Cai/h/e, mugen chip, ZC hybrid tranny, 15.2@82 in my 89 Civic Si...
Built Si motor and tranny with dual carbs and much more.... high 14s I'd assume, in my 87 CRX DX.
