how to: removing clutch pipe??
Old Jan 23, 2003 | 02:17 PM
stRtypR25's Avatar
Default how to: removing clutch pipe??
how do you remove the clutch pipe from the slave cylinder?? is there a special way to do this because if i keep trying, i am going to strip the nut.
Old Jan 23, 2003 | 02:34 PM
stRtypR25's Avatar
Default Re: how to: removing clutch pipe?? (stRtypR25)
anyone??
Old Jan 23, 2003 | 02:46 PM
.RJ's Avatar
.RJ
what do you mean by clutch pipe - the hydraulic line?
Old Jan 23, 2003 | 02:53 PM
stRtypR25's Avatar
Default Re: how to: removing clutch pipe?? (Indecisive.RJ)
yes, the line that goes on top of the slave cylinder
Old Jan 23, 2003 | 02:56 PM
Jowee's Avatar
You have to unbolt the slave cylinder. I believe its 2 17mm or 14mm bolts. From what I remember 2 bolts on the bottom of the it.
Old Jan 23, 2003 | 04:32 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
line wrench is your friend...
Old Jan 23, 2003 | 04:45 PM
sackdz's Avatar
Default Re: how to: removing clutch pipe?? (rodney)
Flare-Nut wrench.
Old Jan 23, 2003 | 05:29 PM
JDM CTR '00's Avatar
Default Re: how to: removing clutch pipe?? (sackdz)
use your fingers or teeth
Shurt24
Jun 25, 2014 08:59 PM
Buktheng
Jan 29, 2008 03:46 AM
MI4$DC5
11
Jan 7, 2007 07:01 AM
illusion
May 3, 2006 03:44 PM
scartail
Aug 29, 2005 03:11 PM
