post your setup and 1/4 mile times w/ your 92-95 hatch w/ b18c
Old Jan 23, 2003 | 09:01 AM
b18cInside's Avatar
Default post your setup and 1/4 mile times w/ your 92-95 hatch w/ b18c
thanks
Old Jan 23, 2003 | 09:02 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: post your setup and 1/4 mile times w/ your 92-95 hatch w/ b18c (b18cInside)
10.73 at 158mph.
Old Jan 23, 2003 | 09:03 AM
Spade's Avatar
Default Re: post your setup and 1/4 mile times w/ your 92-95 hatch w/ b18c (vtecvoodoo)
10.73 at 158mph.
Ha got you beat. 10.72 @ 158
Old Jan 23, 2003 | 09:10 AM
Jin Yamato's Avatar
Default Re: post your setup and 1/4 mile times w/ your 92-95 hatch w/ b18c (Spade)
whoa.
The fastest can I have ever owned is a 96 ek w/h22
Runs low 13's. I suck at launches.
Old Jan 23, 2003 | 09:23 AM
hybrider's Avatar
Default Re: post your setup and 1/4 mile times w/ your 92-95 hatch w/ b18c (jin_)
93 civic si, full interior
B18C1 swap
stock except for act clutch, cm flywheel
14.8@93 2.3 60ft gottaa trim that 60 down a bit more
Old Jan 23, 2003 | 10:39 AM
SpooN Man's Avatar
Default Re: post your setup and 1/4 mile times w/ your 92-95 hatch w/ b18c (hybrider93)
see sig, stock shitty clutch and really poor 60 foot times. 2.3
Old Jan 23, 2003 | 10:41 AM
B_CRUZ!'s Avatar
10.73 at 158mph.
10.28 at 172mph... I need to practice my launches...
Old Jan 23, 2003 | 10:54 AM
MaxBoost's Avatar
New User
Default Re: post your setup and 1/4 mile times w/ your 92-95 hatch w/ b18c (B_Cruz)
95 DX Hatch
B18c1
JDM DC Headers
2.5" Exhaust
AEM Intake
ACT Clutch
Kumho Tires on 16's
14.30@98mph 2.2 60ft
Same as above plus skunk2 intake manifold
13.91@99mph 2.2 60ft
Now I added:
CTR pistons
Jun III cams
Jun Valvesprings and Retainers
B&M Fuel Pressure Regulator
MSD Fuel Pump
Hondata Stage 2
Hondata Phenolic Spacer
Exedy Clutch
Looking for 12.999 on 22*8*15" slicks!
Old Jan 23, 2003 | 11:51 AM
976's Avatar
976
New User
Default Re: post your setup and 1/4 mile times w/ your 92-95 hatch w/ b18c (MaxBoost)
95 DX Hatch
B18c1
JDM DC Headers
2.5" Exhaust
AEM Intake
ACT Clutch
Kumho Tires on 16's
That is a huge drop with skunk2 manifold, wow! Impressive...
Bump...
Old Jan 23, 2003 | 11:53 AM
Chris y0!'s Avatar
Default Re: post your setup and 1/4 mile times w/ your 92-95 hatch w/ b18c (w00t!)
16.6 in a 2000 w/ complete d16y7 swap
w00t~
Old Jan 23, 2003 | 11:57 AM
Plan B's Avatar
B18C1 swap
This depresses me, my 94 ex, b18c1 with 12.5:1 compression is probably going to be right in there with you.
Oh, i'm going to be so embarassed.
Old Jan 23, 2003 | 12:00 PM
Chris y0!'s Avatar
Default Re: post your setup and 1/4 mile times w/ your 92-95 hatch w/ b18c (Plan B)
2.3 60's are you guys serious? my car is pulling 2.3s... with 185/65/14s yo.
Old Jan 23, 2003 | 12:02 PM
jg's Avatar
jg
'94 dx hatch, 2208lbs. with me in it
stock '01 ITR swap
Apexi dunk cat-back + test pipe
205/50-15 drag radials
= 13.6 @ 103mph 1.98 60'
Old Jan 23, 2003 | 12:06 PM
slowdx's Avatar
Default Re: post your setup and 1/4 mile times w/ your 92-95 hatch w/ b18c (Spoon Hybrid)
95 dx coupe with USDM 95 b18c1
14.6@ somethin i forogt ill post timesheet later
Full interior Minus back seats and took out system.
Stock Except For:
Short Ram intake
Exhaust
Old Jan 24, 2003 | 07:38 AM
b18cInside's Avatar
Default Re: post your setup and 1/4 mile times w/ your 92-95 hatch w/ b18c (slowdx)
thanks for all the replys, hopefully ill be somewhere in the 12's when im done right now i have 4-2-1 header, cai, pulleys, skunk 2 i/m, jg t/b, thats it but havent messed w/ the internals yet
Old Jan 24, 2003 | 07:45 AM
Evs-One's Avatar
Solbros Owns Me
B18C1 swap
hmmm. With my almost bones stock 94 Si- at the time I had intake, exhaust, plugs, wires, suspension, and nitto nt450's, and I ran a 15.5 @87mph with a 2.3 60 footer....this is with a broken 3rd synchro. I'm hoping to be high 14's with what I have now. Not trying to dog on you, just doesn;'t seem worth it, although the upgrades are
Old Jan 24, 2003 | 08:23 AM
BauleyCivic's Avatar
Risky Business
10.73 at 158mph.
lol i cant get enough of this guy...
Old Jan 25, 2003 | 11:05 PM
slowdx's Avatar
Default Re: post your setup and 1/4 mile times w/ your 92-95 hatch w/ b18c (Emerica)
B18C1 swap
potential, one of the reasons its worth it
Old Jan 26, 2003 | 12:37 AM
blykins's Avatar
Banned
94 Civic Si Hatch gutted (2430lbs w/out me)--ITS A FATTIE!
JDM ITR swap
APC intake yO!
DC 4-1 GSR header
testpipe
Apexi Worldsport exhaust
Kenji P28 ECU
94/95 GSR wheels w/ Falken Azenis 205/50/15@15psi
14.1@98 w/ 2.1 60'
I have video of it, PM me if you want it.
Old Jan 26, 2003 | 12:45 AM
chad's Avatar
Moderator
10.73 at 158mph.
you got me by.01 seconds....but i have you in mphs i hit 174....i spinning my tires alittle
Old Jan 26, 2003 | 07:23 AM
Agent#ONE's Avatar
12:51@106
94 cx
b18c5
Old Jan 26, 2003 | 08:57 AM
JunelSiR's Avatar
Default Re: post your setup and 1/4 mile times w/ your 92-95 hatch w/ b18c (Agent#1)
25:97 @ 37mph lol w/t 100 shot of NOS!
Old Jan 26, 2003 | 09:16 AM
1 2 NV's Avatar
good luck, u might run 13s if ur lucky.
Old Jan 26, 2003 | 09:19 AM
ATgrills.com's Avatar
Default Re: post your setup and 1/4 mile times w/ your 92-95 hatch w/ b18c (hondaatwsu)
14.72 with a 92 civic HB b18b1 with crower cams (full interior with system)
Tyler
Old Jan 26, 2003 | 12:39 PM
Filliam H. Muffman's Avatar
Default Re: post your setup and 1/4 mile times w/ your 92-95 hatch w/ b18c (ATgrills.com)
94 si--b18c
eagle rods
JE 9.0 pistons
micropolished crank
bored to 85mm and resleeved
mugen dual valve springs
skunk2 valves
skunk2 turbo cams
550cc injectors
MSG ignition
AEM pulleys
boostin 22 lbs
w/ 100 shot of NAWZz y0!
=-=-=-==18.9@70mph=-=-=-=-=-=
must be the ecu
ha. ha. ha.
