Turn Signal Problem After Momo Install
Old Jan 23, 2003 | 05:23 AM
Mocky57's Avatar
Default Turn Signal Problem After Momo Install
Last night, I took my OEM steering wheel off and replaced it with a Momo steering wheel. Everything is great, except one problem.
When I make a turn, and use the turn signal, the turn signal does not shut off automatically when I start going straight again. It keeps blinking. Has anyone had this problem before? Any suggestions to fixing this?
Also, I haven't figured out how to get the horn to work, but I think I've got some ideas on that problem.
Thanks!
Old Jan 23, 2003 | 09:34 AM
Mocky57's Avatar
Default Re: Turn Signal Problem After Momo Install (Mocky57)
Anyone do a steering wheel mod?
Old Jan 23, 2003 | 09:36 AM
nerces's Avatar
i havent yet but my freind has the same problem you do
Old Jan 23, 2003 | 10:21 AM
Daniel's Avatar
it stops blinking once you flick the lever again though, right?
I don't have experience installing steering wheels (mine's still stock), but maybe there's some type of lever on the OEM wheel that flicks the turn signal lever so the light stops blinking once you continue driving straight. Just an idea. . . .
Old Jan 23, 2003 | 02:11 PM
Mocky57's Avatar
Default Re: Turn Signal Problem After Momo Install (Daniel)
Yup. I'm running into problems when I straighten the wheel out..the turn signal still stays on. Yes, it does go back after I flick it back.. otherwise, it'll keep blinking.
When you take off the bolt, underneath there is one white plastic molding comes out. I can't put that part back in because the steering wheel hub won't fit with it on.
[Modified by Mocky57, 6:12 PM 1/23/2003]
Old Jan 23, 2003 | 02:38 PM
sgT's Avatar
sgT
the hub isnt engaging the canceller.
Old Jan 23, 2003 | 02:42 PM
Mocky57's Avatar
Default Re: Turn Signal Problem After Momo Install (sgT)
canceller? can you give me a little more information on what exactly this means? sorry for sounding like a moron.
Old Jan 23, 2003 | 03:42 PM
RSZero1's Avatar
that plastic ring is the canceler, it tells the turnsignal when to turn off in relation to steering wheel position. I did a Momo on my 97, no problems, even have a working horn...all you need is part number 35259-SH3-A02 for 88-91 civics, there was a post just today on making the horn work, search...if your hub won't fit properly, you may be using the wrong hub...good luck
actually, lucky you, - here's the link https://honda-tech.com/zerothread?id=273474
[Modified by RSZero1, 4:46 PM 1/23/2003]
Old Jan 24, 2003 | 02:43 AM
00-ITR-373's Avatar
Default Re: Turn Signal Problem After Momo Install (RSZero1)
ttt - I'd like to know too, if anyone has the answer.
Old Mar 11, 2003 | 06:29 AM
Soundwave9900's Avatar
Default Re: Turn Signal Problem After Momo Install (00-ITR-373)
mine just broke.. i have a stock wheel, but my signal wont go off until i turn it off. it drives me crazy!
Old Mar 11, 2003 | 08:58 AM
ejprimo's Avatar
Default Re: Turn Signal Problem After Momo Install (soundwave9900)
my 1994 civic ex turn signals automatically turns off when i straighten out my wheel, but my cousins 2000 accord ex turn signals have to be shut off manually.
[Modified by ejprimo, 9:58 AM 3/11/2003]
see vick
12
Mar 5, 2021 05:49 AM
Dontoh
Suspension & Brakes
Aug 8, 2011 07:32 PM
1hotintegra
Feb 23, 2003 06:17 PM
