Need help IDing turbo inlet and outlet holes.
Old Jan 23, 2003 | 04:40 AM
BlueShadow's Avatar
Default Need help IDing turbo inlet and outlet holes.
Hi guys,
I just wanted to make sure that I know which holes are which on my turbo.
PIC #1
TOP = Oil Drain
BOTTOM = Oil Feed
PIC #2
TOP RIGHT = Coolant Feed?
BOTTOM LEFT = Coolant Drain?
PIC #3
If this is in fact the oil drain, I may have some issues with the fitting/line being to close to my manifold. Do you guys think that a 45 degree fitting will help with the clearance issues?
Thanks
[Modified by BlueShadow, 5:40 AM 1/23/2003]
Old Jan 23, 2003 | 05:58 AM
boostaholic's Avatar
Default Re: Need help IDing turbo inlet and outlet holes. (BlueShadow)
The oil feed, oil drain, water inlet, and water outlet are going to be 180 degrees of each other. The bottom port on your first pic is the oil feed and directly opposite it on the bottom is going to be the drain (pic 2 bottom left). So the other two are your water ports.
blitzman
Jun 14, 2019 12:21 PM
blaxican05
Jun 1, 2006 07:45 AM
plohipx
Apr 11, 2003 05:06 PM
thejdmkid
Jan 13, 2003 06:38 AM
