High speed stability??
Old Jan 23, 2003 | 12:09 AM
pagong's Avatar
Default High speed stability??
What will make a FF car more stable at high speed? especially in the front. My car tends to sway around on the freeway.
NOTE: I only do high speed runs when there is absolutely nobody near or infront of my car for the next three exits. Usually around 10pm.
Old Jan 23, 2003 | 12:18 AM
BenB's Avatar
Default Re: High speed stability?? (pagong)
If you are going in a straight line and it strays from the center to one side - sounds like you need an allignment.
Stiff suspension and good tires will make a world of difference in how your car rides.
[Modified by BenB, 9:19 AM 1/23/2003]
Old Jan 23, 2003 | 12:28 AM
Street Ghost's Avatar
Default Re: High speed stability?? (BenB)
Old Jan 23, 2003 | 10:37 AM
pagong's Avatar
it doesnt stray, like you mean when you release the steering wheel it drifts left or right? I mean when on the freeway going 100mph the car feels like its floating instead of it feeling like its glued on the road.
Old Jan 23, 2003 | 10:46 AM
fukaintmuven's Avatar
i have the same prob like around 130+(my cluster only shows 130) and my car is ready to give me more. i let go cause it feels like im on a life raft
Old Jan 23, 2003 | 11:15 AM
kommon_sense's Avatar
Default Re: High speed stability?? (fukaintmuven)
Believe it or not, but I noticed that my car became more stable at high speeds after I installed the CTR front air dam. Got even better after I lowered it. I was coming back from a friends place in VA a few weeks ago and hit 95mph without even realizing it. Felt the same as it did at 60mph.
Old Jan 23, 2003 | 11:46 AM
JD_B18CDX's Avatar
Right on!
Sway bars would also help because it will keep the car flat on its 4 wheels all the time.
98R#460
Nov 27, 2014 03:44 PM
Mohsin
Suspension & Brakes
Jul 21, 2008 11:59 PM
Shirozu
May 29, 2008 05:37 PM
MechE00
29
Sep 2, 2003 08:56 AM
CD8
Jul 18, 2002 11:58 AM
