spun beering??
Old Jan 22, 2003 | 05:53 PM
96civich22's Avatar
Default spun beering??
hey what else could be wrong with an engine when it has a spun beering???? and how do you get a spun beering???? i need to know before i get this motor.
Old Jan 22, 2003 | 06:17 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: spun beering?? (96civich22)
I just got a motor with a spun bearing. Everything is fine except that the crank needs machine work and on custom bearing.
Old Jan 22, 2003 | 06:23 PM
sauceman's Avatar
First, don't touch that engine. Reason why: Spun bearing is mainly due to oil starvation, but can also be overrevving, causing oil starvation, excessively high temperatures that can melt the bearings, and they would re-cast in a different shape when it cools down. This happened to me on a rod bearing. It can also be due to a warped block.
This is what it can produce quite quickly: Spun bearings wil either turn on the crank, rods or block. Depending on how long it has lasted, you'd have to replace those parts, or at least get them milled and re-polished, but in any case they won't remain as solid as new ones would. rods are replaceable, crankshaft, maybe too costly. You would also need to re-measure the new bearings to make sure you get everything fitted in there with the right factory tolerances.
IMO don't touch this engine. Could be a can of worms. Look for another.
jv88_dc2
Oct 10, 2012 03:40 PM
SurferDude905
Jun 29, 2009 04:30 AM
racerpat94
Apr 9, 2007 09:41 AM
i-VTEC_do_you
Jul 19, 2006 09:44 PM
HickamHatch
Dec 17, 2005 04:10 PM
