I hate my crx, REVISITED.. Good news.
Well, i posted here awhile ago how i hated my friggin CRX.. WEll, i have had a change in my thinking.. The car leaked water like the titanic... I fixed that problem, turned out to be the rear drain tubes were PLUGGED.... Next problem the car handled like assss.. Turns out that the rear crossmember is split and the shocks are HOLY HELL WORN out.... Only issues that are left are the paint*bad body work* and that it has this weird hesitation, almost like a stuck throttle at low aRPMS... i figure pulling the throttle body and cleaning it will help that issue.. Unless you guys have other ideas??
Now, once i fix the paint, i think i will be fairly happy with the car.... Thanks for the time, and the support when i was BASHING crx's///
Yeah, cleaning the throttle body should work. We did this on my friend's CRX, and that stopped the pedal from sticking just off idle. Don't bother removing the throttle body, just use some throttle body cleaner in a spray can. It's available at any auto parts store.
schock3
Jan 16, 2009 05:59 PM
