Result of a 9200 RPM misshift w/ no rev limiter
Old Jan 22, 2003 | 02:01 PM
VTEC-DA's Avatar
Default Result of a 9200 RPM misshift w/ no rev limiter
My cousin sent me these pics. He misshifted his b16a at 9200 and he doesnt have a rev limiter. on people with no rev limiter. The pics arent too good, but piston 1 is simply not there, its all in the oil pan and the rod is twisted, not bent, but twisted. Piston 3 also has a very large hole in it. 2 valves dropped in each of the two cylinders. Here are the pics:
[Modified by VTEC-DA, 6:02 PM 1/22/2003]
Old Jan 22, 2003 | 02:04 PM
Nameless RB26's Avatar
Default Re: Result of a 9200 RPM misshift w/ no rev limiter (VTEC-DA)
That sux's. Did he say how high his rpm's went after he missed?
Old Jan 22, 2003 | 02:05 PM
HotWheelz's Avatar
wow! impressive ... i thought everybody was telling us how B16's are the ****'s with the rod ratio and stuff.. saying they can do 9k no problem... hmmm.......
i wonder what the the people who condone titanium retainers will say to this one...
hahahaha
Old Jan 22, 2003 | 02:06 PM
Lord Helmet's Avatar
Dammm!!! what the hell was he doing at 9000+ rpm?
nice pics though
VTEC-DA's Avatar
Default Re: Result of a 9200 RPM misshift w/ no rev limiter (Nameless)
He didnt know, well past 10k though.
As far as being at 9000k+, he is one of those guy who is convinced that even with stock cams, his car still pulls hard after 8500, so he keeps going.
[Modified by VTEC-DA, 6:08 PM 1/22/2003]
Old Jan 22, 2003 | 02:07 PM
sjracer's Avatar
i don't think a rev limiter would protect you against that kind of misshift...late
Old Jan 22, 2003 | 02:10 PM
EpDarks's Avatar
Default Re: Result of a 9200 RPM misshift w/ no rev limiter (sjracer)
Correct, a rev-limited would NOT have helped him.
If you grab the wrong gear, your tranny will spin your engine as fast as it wants.
Unless you mean mis-shift as in simply not going into ANY gear at all?
That sucks though.
lol trial and error I guess
There's quite a few ITR owners out there who do this. Shifting at 8,900 as if it's going to help anything.
Old Jan 22, 2003 | 02:11 PM
VTEC-DA's Avatar
But at least they have the ITR cams, which make power a hell of alot higher than the B16a cams do.
Old Jan 22, 2003 | 03:13 PM
rice_classic's Avatar
Default Re: Result of a 9200 RPM misshift w/ no rev limiter (HotWheelz-turboh22dx)
They can, and with the right valve train they can make power up to 10k.
I shift at 9k, safely.
Old Jan 22, 2003 | 03:19 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Result of a 9200 RPM misshift w/ no rev limiter (rice_classic)
nice... memories
Old Jan 22, 2003 | 06:26 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: Result of a 9200 RPM misshift w/ no rev limiter (SIXTYdashONE)
@9200?? Damn, I'm still waiting for the pics to show.
Old Jan 22, 2003 | 06:32 PM
andrewasf77's Avatar
i dont do it, i dont really run my car that hard, but i was under the impression that if you shifted higher then you could stay in vtec in the next gear and not drop out.
Old Jan 22, 2003 | 07:08 PM
RenoRacing's Avatar
Default Re: Result of a 9200 RPM misshift w/ no rev limiter (andrewasf77)
i see no problem shifting at 10k rpms my friend does it all the time.
Old Jan 22, 2003 | 08:02 PM
lazerus's Avatar
Default Re: Result of a 9200 RPM misshift w/ no rev limiter (HavokRacing)
Lesson learned: don't shift into wrong gear.
Old Jan 22, 2003 | 08:23 PM
Kamin's Avatar
Default Re: Result of a 9200 RPM misshift w/ no rev limiter (lazerus)
exactally why removing the rev limiter is POINTLESS without major headwork.
Old Jan 22, 2003 | 08:27 PM
MikeSarr_GSR's Avatar
yea one thing thats true... spectators never get injured. if you race your car you will eventually mis a shift accidentally into a gear and become yet another statistic of pride under fire. those pics look more like it failed under the influence of Nitrous/misshift. there is way too much detonation in the head quench area and tops of pistons to make me think otherwise. better luck next time
Old Jan 22, 2003 | 08:50 PM
Kataku2K3's Avatar
Default Re: Result of a 9200 RPM misshift w/ no rev limiter (MikeSarr_GSR)
Seen that happen a few times with a stock rev limiter.... Those mis shift 1st, 2nd, 3rd, 2nd shifts can kill Oh well scrap the B16 for a B18C... Peace
Old Jan 22, 2003 | 09:29 PM
If you have a honda with vtec, you shouldn't have that problem shifting at the stock redline or even a little bit below it. Honda manufacturers were smart on that subject matter..
Now maybe a celica on the other hand...
Old Jan 22, 2003 | 09:36 PM
SikofFalln's Avatar
Ouch, that is one expensive mistake! My freind's bottom end kinda looked the same after he blew it up with his bottle.
Old Jan 22, 2003 | 10:16 PM
civic_hb96's Avatar
Default Re: Result of a 9200 RPM misshift w/ no rev limiter (BseriesPWR)
i redlined 3rd went into 4th at least i thought is was 4th. turned out to be 2nd, saw my rpms go to 10k+ on a stock b20. the rev limiter doesnt exist whe you do something like this, even if you do have one, cause i did
car was fine for a few weeks. but i musta slapped a valve on a piston which caused a slight crack on the valve cause this is waht happend
you cant really tell from the pic but pieces of the valve are melted to the stem.
bottom end was fine sort of. i found i was burning a lot of oil afterwards, about 2L a week.
the bottom end finally let go in november. it held up for about a year after the valve went. i'm guessing the rings went because i opened it up and it looked fine. no damage to the pistons or valves. compression was like 75 in #4cyl.
Old Jan 23, 2003 | 08:51 AM
canuck-mx6's Avatar
I shift at 9500 all the time ......
Heck, I make my most power at 9200
Old Jan 23, 2003 | 09:13 AM
eg6ajk's Avatar
Default Re: Result of a 9200 RPM misshift w/ no rev limiter (canuck-mx6)
hey my sohc vtec (jdm) d15b (good r/s stroke ratio 1.62:1) has seen few 8500rpm+ runs.
rev limits have nothing to do with misshift. but running no-revlimit on stock car is simply asking for trouble.
Old Jan 23, 2003 | 11:30 AM
Kataku2K3's Avatar
Yea me too man, 15500+rpm... haha j/k Peace
