Where can I find a Del Sol VTEC(B16A) rear sway bar??
I have checked all the local junkyards here in Atlanta. I would like to get the Del Sol VTEC front and rear(rear preferably) sway bar. Most junkyards have no clue if they have one in stock others won't even check. Any ideas where I can look or where I can get a cheap aftermarket sway bar for my 93 Del Sol Si that won't be too big. Thanks in advance for your replies.
just get a gsr or type r sway bar, they'd probably be easier to find. And you'll also be needing gsr or vtec sol rear lca's since your car didn't come w/ a stock rear sway bar.
Wrecking yard, or junkyard whatever you want to call it. I have bought 4 from there for different people's cars and they usually run me about 15-25 dollars.
So will I need the whole rear LCAs from a Del Sol VTEC, GSR, or Type R to put on the sway bar or can I get it done.
even the 13/14mm rear bars is a very nice upgrade and can be had for very cheap.
any EG/DC LCA with a rear sway EXCEPT the ITR , the shock mounts in a different style.
Steve
724chris
Mar 20, 2011 06:21 PM
