16 gauge wire big enough for injector?
i'm not really sure since i'm rewiring a dx harness to work with mpfi. the dpfi mian injector has some fairly beefy wire, i'd guess about 14 gauge.
Plenty big enough, the dpfi uses high impendence injectors, so it needs the thicker gauge wire, but with the mpfi, you have the injector resistor box, so you are putting way less volts thru, so you will be fine.
bestofthe80s
Jun 29, 2017 10:53 AM
DC2-ProdUcTiOnS
May 20, 2009 12:46 PM
Voodooboy520
Dec 3, 2005 03:59 PM
serious
Jan 22, 2003 06:49 AM
