USDM B18c5 or JDM B18c5 ?
Old Jan 21, 2003 | 10:31 PM
Filliam H. Muffman's Avatar
Default USDM B18c5 or JDM B18c5 ?
ok...my question is...i know what the differences between them are...but can the smog people tell? cuzza the VIN on the engine or whatever...and would it make that much of a dfference swapping into a 96 DX hatch. and if i intended on going turbo...should i just forget both and go for the GSR motor? which is better for turbo?
Old Jan 21, 2003 | 10:34 PM
chad's Avatar
Moderator
Default Re: USDM B18c5 or JDM B18c5 ? (JUN EK9)
screw smog!!!!
Old Jan 21, 2003 | 10:39 PM
93SSPHatch's Avatar
JDM Type R hands down. Not unless you can find a USDM ITR for a really great price.
You can get a BAR sticker for your JDM ITR as long as you hook up the USDM exhaust manifold, along with a USDM ITR ECU, and all the proper smog equipment.
As far as GSR vs ITR I would definitely go with the ITR. The better valvetrain/head, higher compression pistons, LSD, and ITR tranny cannot be added to a GSR for the $1500 that they charge between the GSR and ITR.
Turbo? I have talked to a few people that are running minimal boost on their ITR's. They seem to be very pleased with the setup.
Old Jan 21, 2003 | 10:46 PM
Default Re: USDM B18c5 or JDM B18c5 ? (93SSPHatch)
thanks...i hear a lot of people say that....but what is the nessesary smog equiptment?? and im probably going to change the internals on the motor anyways...so do you think boost is a good idea?
Old Jan 21, 2003 | 11:41 PM
xJ.SLOTHx's Avatar
JDM B18C
Old Jan 22, 2003 | 12:05 AM
93SSPHatch's Avatar
Depending on what year the chasis is and what year the motor would be. If you have a OBDI chasis, then the motor needs to be changed to OBDI even if it is an OBDII. The necessary smog equipment would be a catalytic converter, USDM ITR exhaust manifold, PCV, all vacuum lines properly hooked up, EVAP canister properly installed, no adjustable FPR, USDM ITR ECU, no CEL codes, proper timing and idle.
The best way to check and see if you have all the proper smog equipment is to either buy a Helms or to visit the library and photocopy the smog diagrams from an ITR. Overall, it sounds like a lot of items, but once you have the sticker, the rest is simple. MAKE SURE YOU GET THE BAR STICKER BEFORE YOU START MESSING WITH THE ENGINE. After the engine becomes legal to be inside the chasis, then all you have to worry about every two years is passing the emissions part and minor visual.
Good luck. In the end I would still go with the JDM ITR.
Old Jan 22, 2003 | 04:44 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Whatever is cheapest. The JDM ITR motors are a little cheaper then their US counter parts. I had a JDM ITR motor. Toda B's took care of that motor now I have a US ITR motor. I actually feel like the US motor is stronger (In stock trim anyway).
Its geting boosted so its irrelevant.
Old Jan 22, 2003 | 06:29 AM
Maddhatcher's Avatar
Default Re: USDM B18c5 or JDM B18c5 ? (snail_power)
13.9 in a 2000 civic si with intake and exhaust is unheard of. timeslip anyone. i dont believe this one.
[Modified by Maddhatcher, 3:30 PM 1/22/2003]
Old Jan 22, 2003 | 06:37 AM
Spade's Avatar
Read the post in my sig. I made it so the Smog issues wouldn't be an issue.
ActionJackson's Avatar
Default Re: USDM B18c5 or JDM B18c5 ? (Maddhatcher)
i don't know, he does have the "fast" si.
Old Jan 22, 2003 | 06:46 AM
4g4me's Avatar
go with the b16a, i love mine, check out my sig.
a 75 shot and your mods, slicks and a hell of a driver will get a 00 si into the 13's
sorry.
Old Jan 22, 2003 | 07:00 AM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
i dont believe this one either
Old Jan 22, 2003 | 07:13 AM
Hythrax's Avatar
forgive me if that doesn't sound believable.
timeslip, please. i haven't seen EGs run close to that time with the same engine, and your chassis is far heavier. unless you are one of those "i've got a 70hp header" people.
Old Jan 22, 2003 | 07:23 AM
jus f0 dekarayshunZ
Default Re: USDM B18c5 or JDM B18c5 ? (Hythrax)
eg's are heavier than the si bus...uhh where did you get your info...clubsi...haha kidding...seriously 00 red si, pace setter exhaust, dc header, ebay special cai, 13.9 @ 98 mph all motor baby..i/h/e might get an si into high 14's with the best driver in the world...maybe...so uh check up on your info
Old Jan 22, 2003 | 08:41 AM
neonxrt's Avatar
true, but you can get teh JDM GSR swap w/ LSD.....Osaka only charges $200 more.......GSR is the way to go if you are on a budget, otherwise ITR =
MIKE
Old Jan 22, 2003 | 08:57 AM
00MRSi's Avatar
Default Re: USDM B18c5 or JDM B18c5 ? (neonxrt)
for ***** and Giggles, I'd like to see that time slip also.. ****, maybe if i get an Arospeed Front-mount intake (wannabe FMIC), OBX header and Pacesetter exhaust I can have a high 13sec SI also..
Old Jan 23, 2003 | 05:32 AM
IS3Fifty's Avatar
there wont be a VIN plate on the JDM engine, It may be stand on the long block, but other than that you may never have one. It will be more of a hassle to put a JDM engine over a USDM in your car, but I think that JDM is better, little tougher parts. AS for turbo??? to turbo a type r your going to have to put a lot of cash in it. First you need to lower the compression, new pistons, rods, create more clearance in the head. stock compression is like 11:1 for JDM. is it a turboable engine? yes it is, but not without modification. Is a GSR more turbo capable stock? yes very much so.
Old Jan 23, 2003 | 05:37 AM
Apex i ITR's Avatar
Default Re: USDM B18c5 or JDM B18c5 ? (purek9hybrid)
You do not need to lower the compression on a ITR motor. A JDM ITR motor may be slightly higher compression wise....so put a thicker headgasket on and tune the bitch.
high compression turbo motors are just as good and in some cases better then low compression motors, it just depends on what your goals are.
High compression motors just have a smaller margin for error, so don't skimp on the tuning. Get a Hondata (Or equivalent) and tune the car (Or take it to someone who can tune your car) good.
Old Jan 23, 2003 | 06:03 AM
SergEK's Avatar
i have timeslips for my pass, honestly
Remember the 1/8 and the 1/4 mile are completely different.
An EM Si (I/H/E) with 145 whp (maybe) will not run 13.90's
Let me guess slicks, gutted, tail wind , late fall at night with the temp in the 50's and the baro at 31+.......maybe with those conditions...
Old Jan 23, 2003 | 06:58 AM
jus f0 dekarayshunZ
Default Re: USDM B18c5 or JDM B18c5 ? (SergEK)
all he said was i/h/e...thats all he stated...i call bs
Rishiras
Feb 9, 2006 05:13 PM
noxlovexhere
May 4, 2005 04:15 PM
Declectic
Aug 30, 2004 07:49 PM
Hoodwinked
May 23, 2004 10:55 PM
Carpediem291
Oct 5, 2003 10:56 AM
