hatchback owners I NEED YOUR HELP
can somebody that has a 92-00 hatchback or dc2 integra do me a huge favor and measure the distance between their rear seatbelt bolts, where a pillar bar would mount.
i am thinking about getting a J's racing pillar bar for my 94 coupe, but im not sure if it will fit... but i know it will fit in a civic hatch and the dc2 integras.
if someone knows the answer to this id really appreciate it, thanks.
41'' - 42'' that's what i measure... that's with the measuring tape right up to the rear seatbacks..( the front of them, not in the trunk/hatch ) between the two seatbelts. But are you talking about the bolts that hold the female ends of the seatbelts in? Under the seat / the part that you sit on? I thought that rear strut bar went from strut to strut in the trunk area? You said pillar bar , so i'm guessing that you mean the distance from the TOP bolts ( on the sholder belts ) on the back (B?) pillars? right? then that distance is right about 43".
Hope that helps...
Hope that helps...
cool thanks, can anyone else verify that the distance between their c-pillars (from rear upper seatbelt bolts- the shoulder harnesses) is 43"... my coupe is measuring 45" between the c-pillars so i dont think it will work but im not sure how many inches the j's racing bar will adjust. thanks again bro
[Modified by euclid, 2:39 AM 1/22/2003]
they are the same distance eg ek coupe four door hatch dc2 etc...
[Modified by euclid, 4:19 AM 1/22/2003]
ok, im back to squre one on this, aj-racing go tback to me today and said they dont think it will fit b/c it wont adjust out far enough to work on a coupe...
i need one more person to get a measuring tape and measure the distance between the upper bolts for the rear seatbelt shoulder-straps, preferably eh2 or ek....PLEASE
i will bump this for as long as it takes so if you dont want to see this post haunting the front page for the next week,,, take a minute and help a fellow honda-techer out
cool, is that measurment from the actual c-pillar or from the ends of the seatbelt bolt covers? thanks alot man
alright,, mine is deifnately measuring alittle over 45" so they are different, im gonna hold off on the bar untill i can find someone who is actually using the bar in a coupe... thanks again
, no more bumps
, no more bumps
krysted9354
Feb 19, 2009 04:48 PM
