Strong vibration while driving
Old Jan 21, 2003 | 07:01 PM
nEoMuGen's Avatar
Default Strong vibration while driving
I just took my car this morning to FireStone and had a 4-wheel alignment and rebalance/check and bent rims. There were only one with very slight bent that was rebalanced. The car drove fine for the day, but right after I left my friend's house this evening, the car start to behave weird.
First, it was a very noticeable vibration from the right side of the car, it's not like the vibration of a bent rim of blown tire, it seems like the entire right side is swirling. It's most noticeable at 60 and I never had such a sense of danger that I pull off the nearest exit. I check all bolts and they are all tight on the wheels, no tires seem to have any flats (I don't have a gauge handy, so I did a visual check).
I plan to go back to Firestone tomorrow and see what sup, anyone has any clue?
Old Jan 21, 2003 | 07:07 PM
TypeR 599's Avatar
Default Re: Strong vibration while driving (nEoMuGen)
balanced the tires?
Old Jan 21, 2003 | 07:10 PM
nEoMuGen's Avatar
Default Re: Strong vibration while driving (TypeR 599)
balanced the tires?
yeah...that was one of the purpose when I went to Firestone in the morning. Unless they fucked up again. Sheit! I'll never go back there anymore!
Old Jan 21, 2003 | 07:14 PM
TypeR 599's Avatar
have you gone past 60? did the vibrating stop?
Old Jan 21, 2003 | 07:46 PM
Mugen Mike's Avatar
Did they balance the wheel with tape weights? Maybe one fell off.
Could be a wheel was mounted on slightly crooked.
Old Jan 21, 2003 | 07:49 PM
Cosworth's Avatar
Maybe, just your luck that wheel bearing has decided to take crap after the alignment.
Too see if it's the wheel/tire combo, just switch the rear tire/wheel with the front one. You should easily tell the problem by doing this.
Old Jan 23, 2003 | 12:48 PM
Civic 4Banger's Avatar
I have the same problem, except with my civic. I bought some rims, slapped some nitto tires on and installed them with the correct after market lugs. As soon as I left Discount Tire, my car started rattling like crazy. I thought it was that the wheels had been balanced wrong or the alignment was off but after a rebalance and an alignment it kept vibrating. Then I thought maybe my brand new wheels were bent, but nothing was wrong with them. The vibrating starts around 60 for me also and does NOT go away at any speed exceeding 60 but I couldn't test past 116mph because of a limiter hinderance . I am in the same situation as you and maybe someone out there can help me also.
Old Jan 23, 2003 | 12:58 PM
BuKs8n's Avatar
Bent axel? My friends's 98' was doing the same thing and after wheel/tire balancing and alignment it was still there. It turned out to be the passenger side axel. Good luck.
Old Jan 23, 2003 | 03:24 PM
nEoMuGen's Avatar
Default Re: Strong vibration while driving (BuKs8n)
yeah.....axle
read: https://honda-tech.com/zerothread?id=394222
95ejjj
Suspension & Brakes
Dec 1, 2009 07:34 AM
meangreenEG
Oct 6, 2009 07:45 PM
EJ1 wilcox
Suspension & Brakes
Feb 28, 2006 06:27 PM
civic91
May 23, 2005 01:20 PM
LsPower
Feb 28, 2003 01:49 PM
