Will a D15b7 Distributor work in a D16z6?
Old Jan 21, 2003 | 05:07 PM
omahaturbocivic's Avatar
Default Will a D15b7 Distributor work in a D16z6?
Will it? TIA!
Old Jan 21, 2003 | 05:39 PM
slomofo's Avatar
GDD Member
Default Re: Will a D15b7 Distributor work in a D16z6? (omahaturbocivic)
Yes
Old Jan 22, 2003 | 12:43 AM
ImportHatch's Avatar
Default Re: Will a D15b7 Distributor work in a D16z6? (slomofo)
I thought the z6 had a unique bolt pattern for the dist and only a z6 dist will bolt up.
Yager-
Old Jan 26, 2003 | 11:58 AM
Default Re: Will a D15b7 Distributor work in a D16z6? (ImportHatch)
Anyone else know for sure?
Old Jan 26, 2003 | 12:18 PM
BluntMan's Avatar
Yager-
I agree, but im not absolutly positive. just try it and see what happens.
Old Jan 26, 2003 | 12:25 PM
Default Re: Will a D15b7 Distributor work in a D16z6? (BluntMan)
Yea, i dont mind trying it myself, but im borrowing a friends garage so the swap needs to done pretty quick, if I new before I started it would make things simpler. I know the wiring will work becuase im using the dx ecu with a vafc for the vtec. I just hope I can make it bolt up somehow.
Old Jun 19, 2009 | 08:53 PM
willpower102's Avatar
bump
Old Jun 20, 2009 | 04:58 PM
riceburner700's Avatar
no the b7 does not bolt up on all 3 holes. need a z6 dizzy for the z6
Old Jun 21, 2009 | 08:47 AM
912's Avatar
912
just swap out igniter and coil from b7 dizzy to your z6 dizzy
Old Jun 21, 2009 | 10:25 AM
N1 Andy's Avatar
R.I.P. Andy
simply put, no it wont.
the bolt pattern is different.
vtechappy
Mar 23, 2011 11:04 AM
AJxr
Dec 24, 2005 05:13 PM
W O T
Aug 31, 2005 11:58 AM
thenick
Sep 25, 2004 07:20 AM
Br1anPham
19
Feb 6, 2004 09:26 PM
