? On carbs with BSeries VTEC
Old Jan 21, 2003 | 03:00 PM
B16GSR's Avatar
Default ? On carbs with BSeries VTEC
Have a chance to pick up a set of carbs for my gsr from dc4integra. My setup is as follows b16a2 shorty with a jg ported gsr head that has been milled. compression is roughly 11.8 to 1. ctr cams and itr valvetrain. i mainly will be autocrossing the car, and really want them to have something different in my area. have always wanted them and have a chance to do some trading for a set. what all will be needed besides a psi regulator and such? what electronice need to be used?. any input would be appreciated. also this car is not a daily driver, so fuel consumption is no biggie.
Old Jan 22, 2003 | 04:36 AM
B16GSR's Avatar
Default Re: ? On carbs with BSeries VTEC (B16GSR)
no one has any input for me
Old Jan 22, 2003 | 05:53 AM
Philly_NBP_R's Avatar
probably because nobody here (I think) runs carbs. They might be great for throttle response, but emissions, driveability, cold starts, and reliability will all suffer if you switch to carbs - not to mention that there is no way in hell your car would ever pass an emissions / safety inspection. Now if you car is only a track *****, that's a different story.
If you really want inidividual throttle bodies, go here
http://www.twminduction.com/Throttle...leBody-FR.html
and look into a fuel injected setup.
don't let me discourage you though, if you want carbs, get em - there easy as hell to tune I should know, I got 4 of them on my old *** bike...
[Modified by Philly_NBP_R, 9:54 AM 1/22/2003]
Old Jan 22, 2003 | 12:29 PM
NZITR's Avatar
Default Re: ? On carbs with BSeries VTEC (Philly_NBP_R)
I had carbs on my worked AE86 and they were great most of the time. Problems included poor cold performance, heat soak (car would cut out the first time the throttle was pressed) and sharp bumps (power drop out). For a track only car they would be okay but I wouln't consider them for the road.
Old Jan 22, 2003 | 12:31 PM
H-PIMP's Avatar
Default Re: ? On carbs with BSeries VTEC (NZITR)
I've personally never seen a VTEC motor with carbs. But I have seen a turbo D16 motor that was carb'ed.
Old Jan 22, 2003 | 12:58 PM
1.8Tities's Avatar
Default Re: ? On carbs with BSeries VTEC (H-PIMP)
I have a video of J's racing CRX b18c1 running a carb set-up! Very mean sound and fast!!
Old Jan 22, 2003 | 01:14 PM
sgT's Avatar
sgT
Default Re: ? On carbs with BSeries VTEC (4thGSi)
you will need a relay to activate vtec
and i hope you know how to tune carbs, cuz if you drive it daily you are gonna
have to tune it daily
Old Jan 22, 2003 | 01:40 PM
B16GSR's Avatar
Default Re: ? On carbs with BSeries VTEC (sgT)
thanks for the info, the car is a garage queen, it will go out on the weekends for autocross, and the ocassional summer cruise. like i said it is no mean a daily drive. i grew up around tri power corvettes and muscle cars so tuning carbs is no big deal.
thanks for the input it is appreciated
Old Jan 22, 2003 | 02:49 PM
Fuminsho's Avatar
Try this link. It give you a little bit of info on what you will need at the bottom of the page.
http://www.todaracing.com/products/h...ction_kit.html
Old Jan 22, 2003 | 02:55 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: ? On carbs with BSeries VTEC (Fuminsho)
Jesus, with as much crap as I went through getting the Scout to run again after it developed carb problems, I can't imagine anyone wanting them
Pat, who will gladly send you his Holley 2-barrel if you buy him this
Old Jan 22, 2003 | 02:58 PM
MK Ultra's Avatar
Hmm.
I had a pair of Dellortos on my '74 Ghia. They never gave me any trouble. Most of the adjustment was in the linkage, with a little fine tuning here and there every couple of weeks or so.
I love carbs.
Old Jan 23, 2003 | 05:10 AM
B16GSR's Avatar
Default Re: ? On carbs with BSeries VTEC (MK Ultra)
once again thanks for the info, i am going forth with this
Old Jan 23, 2003 | 06:06 AM
good luck,
be sure to post your results...
Old Jan 23, 2003 | 06:08 AM
chrisJ's Avatar
New User
http://www.jdmshit.com/HybridTrackDa...s/DSCF0012.htm
friends b18c with ss works FCR carb kit. ripped the pic off from someone elses sight cant seem to find mine right now
Old Jan 23, 2003 | 06:57 AM
Fuminsho's Avatar
Default Re: ? On carbs with BSeries VTEC (chrisJ)
HEY!!! be sure to give us an update post on the intall and everything you had to do to get the unit up and running right... I and I'm sure others would be VERY interested in the process as well as problems that you ran across to get it going.....
thanks!
Old Jan 23, 2003 | 08:04 AM
B16GSR's Avatar
you guys bet, i will post results for sure, it will just be a measly 1.6 with mildly good compression, but it should spin up pretty good with a lightened flywheel and such.
thanks for all the input
Old Feb 1, 2003 | 08:47 PM
NZITR's Avatar
= i grew up around tri power corvettes and muscle cars so tuning carbs is no big deal.
Biggest difference is that Vtec engine is so highly tuned they will be very sensitive to changes in the conditions.
Good luck if you choose to do it anyway
Old Feb 1, 2003 | 08:52 PM
Nameless RB26's Avatar
Is there some sort of hidden power to be made when using a carb?
I'd guess that you could make even more power with programmed fuel injection. All you have to do is tune the control unit..
Old Feb 1, 2003 | 09:04 PM
NZITR's Avatar
Default Re: ? On carbs with BSeries VTEC (Nameless)
Carbs can flow better than a stock manifold plus you get the quad butterflys for response.. nothing you can't get with a ITB setup if you are willing to spend the $$$.
DA93teg87
13
Nov 25, 2016 01:39 PM
spdwrks
Jan 2, 2008 06:25 AM
SQ is the SQUAD
18
Feb 20, 2005 04:26 PM
paulzy
Feb 19, 2004 11:42 PM
renzema
Apr 1, 2003 11:26 AM
