ITR and other OEM Honda/Acura Rims
Old Jan 21, 2003 | 12:22 PM
FourDoorGSR's Avatar
Default ITR and other OEM Honda/Acura Rims
What other Honda/Acura OEM wheels will fit on the ITR 5lug pattern aside from the ITR white and gunmetals? Can you please list down the Car, year, and wheel size that does fit? Pics would be nice too.
Old Jan 21, 2003 | 12:23 PM
B2FiNiTY's Avatar
Default Re: ITR and other OEM Honda/Acura Rims (FourDoorGSR)
S2K fronts
97+ prelude
97+ prelude SH
I think NSX fronts too.
[Modified by B2FiNiTY, 1:23 PM 1/21/2003]
Old Jan 21, 2003 | 12:29 PM
Do you happen to know the wheel size as well? And how is the offset on the wheels as I am worried that the wheels will stick out way too far from the fenders of the car and possibly rub or worst of all look like it doesnt fit.
Old Jan 21, 2003 | 12:31 PM
Cosworth's Avatar
Default Re: ITR and other OEM Honda/Acura Rims (B2FiNiTY)
97+ prelude : 15x6.5" +55mm offset
I don't know the other figures.
Old Jan 21, 2003 | 12:44 PM
typer_801's Avatar
Accord V6
Acura CL V6 98-00
Honda Odyssey (I think)
Honda CRV 97-00
+ all others mentioned
Old Jan 21, 2003 | 12:51 PM
Obee1.8's Avatar
Default Re: ITR and other OEM Honda/Acura Rims (Cosworth)
97+Preludes are a 16" are they not?
Old Jan 21, 2003 | 12:56 PM
nsxtasy's Avatar
H-T Order of Merit
NSX fronts are not a direct bolt-on.
First, you'll need some hubcentric rings, because the centerbore on the NSX front wheels (all years) is bigger than the ITR's (70 mm vs 64).
Second, you'll need some spacers, because the offset on the NSX front wheels is greater (55 mm vs 50 for the ITR) and they'll rub on the suspension components in the rear. The 15" NSX front wheels will, anyway.
GRM Scott's Avatar
25 Year Member
Default Re: ITR and other OEM Honda/Acura Rims (Obee1.8)
they are indeed 16's, at least in US...
Old Jan 21, 2003 | 01:01 PM
Default Re: ITR and other OEM Honda/Acura Rims (nsxtasy)
Thanks for the info on the NSX rims. I had seen the pre 98 Realtime ITR with the NSX rims before and thought that it would be a direct bolt on as well.
Anyone else try any of these other rims on an ITR to see if there are any clearance/offset problems?
Old Jan 21, 2003 | 01:02 PM
Cosworth's Avatar
Default Re: ITR and other OEM Honda/Acura Rims (Aleph)
oops, yes, they are 16". on me.
Old Jan 21, 2003 | 01:47 PM
BABY NSX's Avatar
NSX wheels DO fit without ANY rubbing. I've been running with them for three years now. It is close in the back end but they don't rub...
Old Jan 21, 2003 | 01:58 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: ITR and other OEM Honda/Acura Rims (BABY NSX)
Baby, you have the 16" front wheels from the '94-01 NSX. Those don't rub, but they're generally pretty expensive, even for used ones. The 15" front wheels from the '91-93 NSX, which can be had quite cheaply, definitely DO rub on the rear suspension of the ITR, and rub hard. I've tried it myself; just trying to inch the car forward is like driving around with the parking brake on.
Old Jan 21, 2003 | 02:09 PM
How much are the going rates for the 16" front NSX rims?
Does anyone have a link to that site that sells used OEM wheels that has pictures?
Old Jan 21, 2003 | 02:23 PM
slowassR's Avatar
mucho $$$$ . I think around 300$ each for factory nsx wheels. More if you get them from acura.
Old Jan 21, 2003 | 02:24 PM
nsxtasy's Avatar
H-T Order of Merit
New and with a great discount, they're around $600. EACH. Used, they rarely come up for sale except in sets of four (two 16" front, two 17" rear), with sets going for $1200-2000, depending on condition, or more if there are good tires on them.
And you STILL need to get hubcentric rings for them (and they're not easy to find, probably easier to have someone fabricate).
Not exactly a practical solution. It would be much cheaper and easier to pick up a set of 16" JDM ITR wheels on eBay.
Sure. Click here. However, just because they have a wheel listed, doesn't mean they actually have any to sell. But the pictures are handy.
New??? Dream on...
[Modified by nsxtasy, 5:28 PM 1/21/2003]
Old Jan 21, 2003 | 02:36 PM
kkim's Avatar
rsx
Old Jan 21, 2003 | 03:05 PM
OK here is the list I have so far... Please let me know if there is more to add. I would like to know if anyone has any personal knowledge of how well these rims will fit on an ITR.
Acura NSX -- 16x7 (will need hubcentric)
Honda S2000 Front Wheel -- 16x6.5
Honda Prelude 97+ Type-SH -- 16x6.5
Honda Prelude 97+ -- 16x6.5
Honda Accord V6? -- 16x6.5
Honda Accord -- 15x6.5
Honda Accord -- 16x6.5
Acura CL 2001-2002 -- 17x7
Acura CL 2001-2002 -- 16x6.5
Acura RSX -- 16x6.5
Acura RSX -- 16x6.5
Old Jan 21, 2003 | 03:22 PM
zer0zer0 TypeR's Avatar
i think fourdoorgsr just answered everyone's questions
Old Jan 21, 2003 | 03:32 PM
RTW DC2R's Avatar
Default Re: ITR and other OEM Honda/Acura Rims (zer0zer0 TypeR)
these own
Old Jan 21, 2003 | 03:35 PM
BABY NSX's Avatar
Default Re: ITR and other OEM Honda/Acura Rims (RTW DC2)
Repost:
and
Old Jan 21, 2003 | 03:39 PM
Eric R's Avatar
Why someone would put heavier or more expensive wheels on their ITR? Beside, they're ugly!
Old Jan 21, 2003 | 03:42 PM
Tommy_Gunns's Avatar
Default Re: ITR and other OEM Honda/Acura Rims (Tweety R)
Accord V6 15" rims???
Old Jan 21, 2003 | 04:35 PM
jetydosa's Avatar
25 Year Member
Default Re: ITR and other OEM Honda/Acura Rims (Tommy_Gunns)
97-03 CR-V 15x6 definitely fit
I am 99% sure 91-95 Legend will fit too, both the 15" and 16"
I am 98% sure the 95-98 Odyssey will fit, the 15" as well as the 16 already mentioned...
Old Jan 21, 2003 | 09:46 PM
rudeS2k's Avatar
Default Re: ITR and other OEM Honda/Acura Rims (Jetydosa)
don't forget about the 16" jdms
Old Jan 21, 2003 | 10:13 PM
vtec.dc2's Avatar
the 16x7 wheels (1994-2001) you have are +55mm offset? Do you know the weight of these? They look very nice
