are B16 and B18 pistons the same size?
Old Jan 21, 2003 | 12:24 AM
turbohf's Avatar
Default are B16 and B18 pistons the same size?
are the pistons the same bore? and will a B16 piston bolt to a LS rod or the other way around??? thanks...
Old Jan 21, 2003 | 12:56 AM
RenoRacing's Avatar
Default Re: are B16 and B18 pistons the same size? (turbohf)
yes, yeah, yes
Old Jan 21, 2003 | 01:13 AM
turbohf's Avatar
Default Re: are B16 and B18 pistons the same size? (HavokRacing)
thank you! to the point with no BS i like that!
Old Jan 21, 2003 | 02:37 AM
BudaKai's Avatar
The domes are different though...
Old Jan 21, 2003 | 08:35 AM
martini's Avatar
Default Re: are B16 and B18 pistons the same size? (tzsir)
valve reliefs are different as well. LS valve reliefs are smaller.
Old Jan 21, 2003 | 12:25 PM
RenoRacing's Avatar
Default Re: are B16 and B18 pistons the same size? (martini)
no problem, i had to reply before someone was an *** about it and put "try the search button newbie" lol
Old Jan 21, 2003 | 12:27 PM
turbohf's Avatar
ok so the REALLY question is: can i put LS/PR4 pistons in a 1st gen B16???? and does anyone know the aprox compression ratio? thanks
Old Jan 21, 2003 | 12:29 PM
sgT's Avatar
sgT
you CAN.
the valve reliefs would have to be enlarged and the resulting CR would be
somewhere around 9:1
Old Jan 21, 2003 | 12:35 PM
turbohf's Avatar
Default Re: are B16 and B18 pistons the same size? (sgT)
damn so i really have to have them inlarged? how much should that cost?
Old Jan 29, 2003 | 04:23 PM
V3locity's Avatar
for an accurate CR, go to
http://www.c-speedracing.com/howto/c...c/compcalc.php
[Modified by illdezignzls, 8:23 PM 1/29/2003]
Old Jan 29, 2003 | 05:43 PM
turbohf's Avatar
Default Re: are B16 and B18 pistons the same size? (illdezignzls)
yeah found that...8.6:1....
Old Jan 29, 2003 | 07:21 PM
sslude's Avatar
nice compression ratio for a turbo...mmmmm
Old Jan 29, 2003 | 07:41 PM
Kataku2K3's Avatar
Default Re: are B16 and B18 pistons the same size? (sslude)
Why would you want to do this?? I'm just curious... If you are building a motor for boost and you are pulling the motor apart why not just go with some forged slugs... They'll take it a lot better... If you are building an NA motor then I would look into OE PCT slugs... Being that you have a B16A it's not going to bump your C/R like they would in a B18A/B/C but they are the highest compression OE piston... Good Luck with whatever route you take.. Latez
spens 91 Ef
25
Jan 29, 2017 09:14 PM
Civic89stdB16
Oct 21, 2009 07:27 AM
a1320honda
Jan 14, 2009 06:30 AM
turboekcivic
Aug 8, 2004 01:25 PM
91civicDXdude
Jul 16, 2003 02:20 PM
