si motor in std hatch (searched but found no answer)
Old Jan 20, 2003 | 07:32 PM
HatchBox's Avatar
Skoobie no more...
Default si motor in std hatch (searched but found no answer)
alright i searched for like 4 pages and still couldnt find this but what all do i need to put the 90 si motor in the civic std hatch???
i know i need mpfi and that but what else do i need
Old Jan 20, 2003 | 09:09 PM
Malgerus's Avatar
Default Re: si motor in std hatch (rsk436)
Get an Si trans.
Old Jan 20, 2003 | 09:22 PM
Louie B.'s Avatar
It bolts right in. No extra modification reqd. You will need the ECU if you're swapping the mpfi with it. (as well as modifying the wire harness for mpfi)
The Si tranny would be nice for performance, but is not required to get the job done. I would recomend putting a new clutch in while the engine's out anyway.
Old Jan 21, 2003 | 02:58 AM
HatchBox's Avatar
Skoobie no more...
Default Re: si motor in std hatch (thumpu77)
dont i need si hubs or something like that?
Old Jan 21, 2003 | 03:50 AM
Mugen Dom's Avatar
u can use ur stock std axles in the si trans if u use that the inner joints are the same on the std trans do a search on how to convert to mpfi and ull understand how to convert the wring harness
Old Jan 21, 2003 | 10:14 AM
HatchBox's Avatar
Skoobie no more...
Default Re: si motor in std hatch (JdMB16Ahatch)
so basicly beside the Motor tranny ecu all i need is mpfi?
Old Jan 21, 2003 | 06:50 PM
Louie B.'s Avatar
yep
Old Jan 21, 2003 | 06:57 PM
Hondasaurs's Avatar
When I put my ZC in my STD hatch I used the STD axels. This saved me the trouble of swapping the hubs. I have the Si tranny. There should be no problem using the STD axels.
Old Jan 21, 2003 | 08:17 PM
USDM 4G VTEC's Avatar
Default Re: si motor in std hatch (ZC_CRX)
same thing i did
i tried upgrading to Si axles but they didnt work (before i knew about hubs) and the STD ones are thicker
Old Jan 22, 2003 | 03:15 AM
HatchBox's Avatar
Skoobie no more...
Default Re: si motor in std hatch (JDM EF9)
awesome
teal91
Jan 2, 2009 10:27 AM
extensioncordy
22
Sep 22, 2006 03:18 AM
buckNasty
Dec 9, 2003 10:55 AM
88rexdxa6ed
11
Apr 18, 2003 06:29 AM
shoebox
10
Oct 29, 2002 07:38 AM
