Drag Racig Facts and Figures
Old Jan 20, 2003 | 06:35 PM
DB2-R81's Avatar
25 Year Member
Default Drag Racig Facts and Figures
* One dragster's 500-inch Hemi makes more horsepower then the first 8
rows at Daytona
* Under full throttle, a dragster engine consumes 1 1/2 gallons of
nitro per second, the same rate of fuel consumption as a fully loaded
747, but with 4 times the energy volume.
* The supercharger takes more power to drive then a stock hemi makes.
* Even with nearly 3000 CFM of air being rammed in by the supercharger
on overdrive, the fuel mixture is compressed into nearly solid form
before ignition. Cylinders run on the verge of hydraulic lock.
* Dual magnetos apply 44 amps to each spark plug. This is the output
of an arc welder in each cylinder.
* At stoichiometric (exact) 1.7:1 air/fuel mixture (for nitro), the
flame front of nitromethane measures 7050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above
the stacks at night is raw burning hydrogen, dissociated from
atmospheric water vapor by the searing exhaust gases.
* Spark plug electrodes are totally consumed during a pass. After 1/2
way, the engine is dieseling from compression--plus the glow of exhaust
valves at 1400 degrees F. The engine can only be shut down by cutting
off its fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds
up in those cylinders and then explodes with a force that can blow
cylinder heads off the block in pieces or blow the block in half.
* Dragsters twist the crank (torsionally) so far (20 degrees in the
big end of the track) that sometimes cam lobes are ground offset from
front to rear to re-phase the valve timing somewhere closer to
synchronization with the pistons.
* To exceed 300mph in 4.5 seconds dragsters must accelerate at an
average of over 4G's. But in reaching 200 mph well before 1/2 track,
launch acceleration is closer to 8G's.
* If all the equipment is paid off, the crew worked for free, and for
once NOTHING BLOWS UP, each run costs $1000.00 per second.
* Dragsters reach over 300 miles per hour before you have read this
sentence.
Old Jan 20, 2003 | 07:01 PM
TREVER's Avatar
Default Re: Drag Racig Facts and Figures (DB1-R81)
repost still gets a
Old Jan 20, 2003 | 08:07 PM
E-Town4229's Avatar
Default Re: Drag Racig Facts and Figures (TREVER)
thanks mr wizard!
-Roger
Old Jan 21, 2003 | 11:14 AM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
Default Re: Drag Racig Facts and Figures (E-Town4229)
NFJohn
Jun 2, 2004 08:09 PM
BeavisB16
Nov 18, 2003 10:59 AM
BHSCGSR
Jan 13, 2003 03:59 PM
