new Crower valvetrain B series VTEC
Old Jan 20, 2003 | 06:18 PM
salt's Avatar
Default new Crower valvetrain B series VTEC
This lists for over $700 I'm asking $380 shipped
Brand new crower valvetrain. Includes valves,retainers,and springs. Valves are stock size. The retainers are shorter inst ht (+.060" inst ht). These assume you have the type R lost motion assemblies. The springs are B Series VTEC Dual Spring
any questions email tradersalt@hotmail.com
picture: http://www.hondaproject.com/parts/crower.jpg
description: http://www.crower.com/cat/import/honda/valvetrain.shtml
Crower titanium retainers are CNC machined in-house to insure quality and batch to batch consistency. Crower titanium retainers are the perfect combination of strength and lightweight design and are specifically designed for Crower, Eibach and factory valve springs. Features profiled design for added camlift and retainer-to-valve seal clearence.
Crower's spring and retainer kits are available for the VTEC (H22/B16A/B18C) as well as the LS/RS (B18A/B) engine platforms. The Crower VTEC springs are wound from a super clean alloy and are rated to 10,000 rpm (VTEC) when used in conjunction Crower titanium retainers (see below). Crower springs are engineered for street or race applications and are the best value in the industry. For those with higher aspirations, Crower is pleased to partner with our friends at Eibach for the highest quality, race only valve spring available on the market. Drop-in installation, no machine work required. Works with stock valves and keepers, but be sure to check out Crower's inventory of high quality stainless steel valves listed below.
Crower is pleased to introduce a new line of premium quality stainless steel valves for the Honda/Acura VTEC engine platform (B16A/B18C, H22, D16Z/D16Y and B18A/B LS). Made from the highest grade stainless steel available on the market, this new Crower valve is a must for high horsepower, high boost and high rpm applications. The exclusive "Pro Flo" head design delivers a significant increase in cylinder head flow figures, while the tip area is hardened to RC50, including past the critical keeper groove area for added strength. Fully CNC machined and swirl polished to insure that you will get the best performance valve available on the market.
68185 B Series VTEC Dual Spring
87093D Titanium Retainers for , B Series VTEC w/ shorter inst ht (+.060" inst ht) 5.5 grams
97400-I B Series VTEC - Intake valve with stock head diameter (33mm). Set includes 8 pcs. 44.7 grams
97400-E B Series VTEC - Exhaust valve with stock head diameter (28mm). Set includes 8 pcs. 35.6 grams
civicboy07
Jun 15, 2014 08:49 PM
StrokedPSI
Feb 1, 2009 07:02 AM
00trdtaco
Jan 31, 2009 07:17 PM
