What is an altenator solenoid valve
what does it do? what would cause this fuse to keep blowing? anyone know a friend just bought a 89 hf and it doesnt run .......we replaced all the fuses and this fuse keeps poping......any help will work.........TIA
From: I told you to wait in the truck in Texas, United States
The first thing to check is probably the alternator..
There is not really an "alternator solenoid valve"
There should be a comma between the two...
Fuse #14 powers the following:
Alternator (voltage regulator)
Emission control solenoid valves
PGM-FI main relay
PGM-FI ECU (IG1)
FUEL PUMP
ELD=eletronic load detector
EACV=electronic air control valve
Unplug those components one at a time until the short disappears..
PGM-FI main relay
PGM-FI ECU (IG1)
FUEL PUMP
Try unplugging the EACV and see if it goes away..
If the valve inside it sticks,it can draw too many amps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">Try unplugging the EACV and see if it goes away..
If the valve inside it sticks,it can draw too many amps.</TD></TR></TABLE>
Wanna help me out pointing what that is? (I got a B16)
Did this problem ever get solved?
Im popping the same related fuse that control all that stuff.
Could a faulty alternator be causing these headaches?
pettyboy69
Jan 25, 2010 09:32 PM
Jonny Rocket
Jul 12, 2009 09:27 PM
