itr compression ratio..
Old Jan 20, 2003 | 08:08 AM
p-boy's Avatar
Default itr compression ratio..
im buying a jdm motor itr.. how much compression should i look for? i mean in the gauge it will sayo something like 180 or something how do i convert it to like 11.5 or something?.. and whats the stock compression ratio of the jdm itr motor? in psi plsss..
Old Jan 20, 2003 | 08:36 AM
b18cya's Avatar
Default Re: itr compression ratio.. (p-boy)
http://www.bseries.net/html/specs/benginespecs.php
B18C 96+ Spec-R /
98+ Spec-R JDM 96-00 Integra Type-R (JDM)
1797cc
DOHC VTEC
11.1:1 c.r.
Old Jan 20, 2003 | 10:35 AM
sgT's Avatar
sgT
you cant convert compression test numbers into an actual compression ratio.
Too many variable factor in which make it near impossible to guess.
Just look for around 200-220 on the comp tester and make sure all 4 are within 5-10 of each other
Old Jan 20, 2003 | 10:45 AM
leadfoot78's Avatar
Default Re: itr compression ratio.. (sgT)
If its out of the car cold and motor is turned by hand look for 130-150 psi. Thats what my JDM GSR did when i turned it by hand after i put it in the car turned it on warmed it up and turned it with the started it did 220/210/215/215.
Old Jan 20, 2003 | 02:00 PM
1bad-eg's Avatar
Itr block should be at about 240 psi.
Old Jan 20, 2003 | 03:26 PM
p-boy's Avatar
Default Re: itr compression ratio.. (1bad-eg)
well? guys? 220 ? or 240? if i turn it by hand?
Old Jan 20, 2003 | 10:13 PM
leadfoot78's Avatar
The manual says that 184psi is the minimum so if you are above 200psi it's fine.
94typeR
May 7, 2007 04:32 PM
88 rex
Dec 17, 2006 01:55 PM
92 EH2
Nov 27, 2005 03:59 PM
TEAM562racing
Oct 15, 2003 01:55 PM
