99si Skunk2 manifold
Old Jan 20, 2003 | 05:12 AM
Chronicsinners's Avatar
Default 99si Skunk2 manifold
my freind and i have bought one recently i we would like to install it ourselves. I am reltivly mechanically inclined, ive installed a couple suspensions and other stuff, but very little motor work. How difficult is it to install? time required? and what exactly is invoked by installing it, what do we need to do, simple swap? howto? thanks alot
Old Jan 20, 2003 | 06:48 AM
Ferrell's Avatar
Default Re: 99si Skunk2 manifold (Chronicsinners)
very considering it was made for the b18c1 head. ITR intake mani will bolt up to the b16 head.
a GSR head.
Old Jan 20, 2003 | 07:12 AM
qcoffey's Avatar
Default Re: 99si Skunk2 manifold (Ferrell)
On Skunk2 website they do have a listing for the 99-00 Si. I was thinking of purchasing the same manifold. If it is then the work should be minimal, probably 3-4 hours max.
If their website is correct then it should be a bolt in affair. Please correct me if I'm wrong, I'd hate to invest in something that won't fit.
Old Jan 20, 2003 | 11:13 AM
kanzenr91si's Avatar
skunk2 makes a im for a b16a/b18c5 and a different one for a b18c1. so as long as you have the right one it will bolt up pretty easy.
Old Jan 20, 2003 | 02:02 PM
Default Re: 99si Skunk2 manifold (kanzenr91si)
we got the one for the 99si, the right one, its just as simple as unbolting the old one and all connecting sensors and bolting this one up? any complications to be foreseen?
Old Jan 20, 2003 | 02:14 PM
WS6Dreams's Avatar
Just make sure you drain your coolant first. You don't have to drain it all, just about halfway. Personally, I would just drain it all and flush the coolant system while you're at it, and then it's just nuts and bolts and sensors. Make sure you get all of the old gasket off before the new one goes on.
EgxHaTcHxGsR
Mar 22, 2019 11:35 PM
ramhorn15
Oct 25, 2006 07:36 AM
iTR.EX
Dec 17, 2002 06:05 AM
Racerj404
Nov 23, 2002 06:38 PM
