Jackson Racing - 12PSI M62 for LS (yes really) or TypeR
Old Jan 20, 2003 | 03:57 AM
The LS Avenger's Avatar
25 Year Member
Default Jackson Racing - 12PSI M62 for LS (yes really) or TypeR
Eaton M62, spins to 12+ psi, on for 20K miles. Normal Jackson supercharger for LS is 30 percent smaller M45 blower at 6 PSI. 190 wheel hp / 160 lb-ft torque (est).
This supercharger fits either a 1990-2001 B18 (LS, non VTEC) motor, or can be switched back to its original configuration for a 1997-2001 b18c5 TypeR motor. It will NOT fit a B18c1 GSR motor. See here for more details: http://www.theoldone.com/articles/conversion/
The 12psi was acheived through a 4.0" nose pulley plus a stepper pulley off the alternator. Normally the kit runs 5 PSI (on a TypeR). Each pulley swap is good for about 3 PSI, plus they enhance each other. Without the stepper pulley it would probably run 8-9 PSI. If you swap back the nose pulley to 4.2" (what it came with) it'll be more like 6-7 PSI on a LS engine since the crank pulley is larger than a TypeR.
This is a complete, running kit installed on a car that was rear-ended and totalled. All parts are available.
90K service already done (timing belt, water pump etc) oil changed less than every 5K miles
All fueling mods to support 12 psi operation (FMU, FPR, 310cc injectors)
Ideally I would be able to pull the engine (80K) + SC + trans and clutch --- clutch and trans are new as of Oct 2002.
[Modified by The LS Avenger, 5:02 AM 1/20/2003]
[Modified by The LS Avenger, 5:28 AM 3/23/2003]
Old Jan 20, 2003 | 08:33 AM
ATgrills.com's Avatar
Default Re: Jackson Racing - 12PSI M62 for LS (yes really) or TypeR (The LS Avenger)
holly crap!!!
Talk about getting fucked in the ***.....
bump for a guy with half a car!
Old Jan 21, 2003 | 05:15 AM
TurboR1391's Avatar
Ouch that had to hurt! TTT
Old Jan 23, 2003 | 07:19 PM
civura R's Avatar
Default Re: Jackson Racing - 12PSI M62 for LS (The LS Avenger)
how much shipped to ca?
Old Jan 23, 2003 | 08:33 PM
carbonblackeh's Avatar
How much??
Old Jan 25, 2003 | 03:08 PM
InTeGrA B18b1's Avatar
want to sell me the lip?
Old Jan 25, 2003 | 05:11 PM
743power's Avatar
Default Re: Jackson Racing - 12PSI M62 for LS (InTeGrA B18b1)
how much shipped to 08638 nj
Old Jan 26, 2003 | 11:58 AM
96IntegraRS's Avatar
I can vouch for LS Avenger-good guy.
Old Jan 27, 2003 | 02:50 PM
Smashback's Avatar
Damn, I guess the secret behind the JRSC superchargers is only apparent when in reverse...must have been hauling ***, backwards!
Joe should appreciate that
Old Jan 27, 2003 | 08:52 PM
falcongsr's Avatar
What is this crap?
Default Re: Jackson Racing - 12PSI M62 for LS (Hatchblack)
hmmmm
Old Jan 27, 2003 | 09:26 PM
roydogg's Avatar
Default Re: Jackson Racing - 12PSI M62 for LS (falc0n)
After reading the post I don't see a price... How much for the lip I'll come and pick it up
Old Jan 29, 2003 | 04:48 PM
i asked first i have to shipp but ill pay it
Old Jan 30, 2003 | 12:00 AM
Type Wah's Avatar
HOw much for the supercharger? please be cheap, please be cheap!
get at me
Old Jan 30, 2003 | 12:19 AM
BudaKai's Avatar
Default Re: Jackson Racing - 12PSI M62 for LS (Wild Rice)
hmmmm
I bet I know about the lines your thinking.
Old Jan 30, 2003 | 08:37 AM
Type Wah's Avatar
don't part it out dude, sell the whole kit.. peeps like that, some peeps like looking for all their **** at piece by piece, but if i had 2gz, i'd buy it right away.. Kit sounds good to me
Old Jan 31, 2003 | 06:35 PM
pls stop asking about the lip !!
what a punk
Old Feb 2, 2003 | 07:29 PM
roydogg's Avatar
Is the lip really that scraped up?
Old Feb 2, 2003 | 09:14 PM
Rory Breaker's Avatar
Ill come get the lip with cash tomorrow, and Im local
TTT...this is a very cool SC kit, especially popped onto an ITR or swapped into a hatch...$2k with all those extras is a killer deal!
Old Feb 8, 2003 | 09:32 PM
roydogg's Avatar
Do you have a type r sway bay on there or some rear bars forsale?
Old Feb 9, 2003 | 08:34 AM
robbieshonda's Avatar
yea what you want for the ls motor?
needs new motor alittle to much vroooom pssst and my motor went boom!
Old Feb 16, 2003 | 10:34 PM
g2teg's Avatar
Hey let me know if that JRSC is still for sale....I just hapen to have some cash in the bank.
Old Feb 17, 2003 | 10:33 AM
g2teg's Avatar
Well, if you want to sell the whole JRSC kit I will buy it, but I have to know soon b/c I am running high compression now, but i am getting my block sleeved and bored, so I need to know if I should get high or low compression pistons.
Old Feb 17, 2003 | 12:47 PM
g2teg's Avatar
Ive p&ped the head. I have stage 2 cams, dual springs, Ti retainers, skunk 2 valves(nitride coated) . I just want to bore it to 2020cc/85mm and the stock cylinder walls will not like that.
Old Feb 17, 2003 | 02:20 PM
g2teg's Avatar
Right now I have the eagle rods. When I get it sleeved I will get Arias pistons. As for as engine management. I have a vafc and a chipped ecu.
Old Feb 25, 2003 | 10:07 PM
roydogg's Avatar
ttt for ya .
