Average compression for the K20A2 motor?
Old Jan 20, 2003 | 01:26 AM
sjracer's Avatar
Default Average compression for the K20A2 motor?
i just got done doing a compression test on my K20A2 motor...it ranged anywhere from 177 psi's to 189 psi's at WOT...cylinder one had 185 psi's...cylinder two had 181 psi's...cylinder three had 177 psi's...cylinder four had 189 psi's...
i've read before that good compression for this motor is at about 206 psi's (not sure if it was fact or someone heard it from someone else)...the problem with this, i have also read about someone taking their car into acura for a compression test and they got 185 psi's across all four cylinders and acura told them they had "good compression"...
So my question to you guys: What's good/average compression on the K20A2 motor? (if it matters...the motor has 5,600 miles on it...not sure if the rings have fully seated yet...maybe that's why number 3 is a little lower then the rest)...thanks
Edit: The Helm's manual doesn't say what good compression is...it just says it shouldn't be bellow 135 psi's and the maximum variance between all cylinders should not exceed 28 psi's...
[Modified by sjracer, 9:27 PM 1/20/2003]
Old Jan 20, 2003 | 12:28 PM
sjracer's Avatar
Default Re: Average compression for the K20A2 motor? (sjracer)
bump
Old Jan 20, 2003 | 09:02 PM
sjracer's Avatar
ATTN: moderator...can you please move my post over to the RSX/ EP3 forum...thanks
Old Jan 21, 2003 | 03:28 AM
sauceman's Avatar
Start yourself a thread in that forum and post a link to this thread here.
floatfisher
May 30, 2006 10:09 PM
Spectrum24x
Jan 15, 2006 05:08 PM
sdinteg
Feb 1, 2005 07:52 PM
sjracer
Jan 22, 2003 02:04 PM
