B16a timing belt on a b18b?
Will this work, i have a power enterprise timing belt for my old b16a...i never got to install it with my Toda B's.
I now have a b18b in my h/b and will be sooon running crower cams...and wondering if i can use it.
I know the high lift cams give honda timing belts fits....so i don't want to bend valves on this motor.
I just was curious if anyone had tried before i pull the belt on my b18b... it has 45k and stock belt.
Thanx
Thanx
Nope won't work. Although if you decide to use a VTEC water pump you have to use a GSR/Type-R timing belt. Hope that helps! Lates!
[Modified by Integra-T, 10:49 PM 1/19/2003]
