B18C headbolt ??
Old Jan 19, 2003 | 05:28 PM
slooowDX's Avatar
Default B18C headbolt ??
i did a search on headbolts, didn't really find anything. can i use my GSR headbolts on a B16A or will they be too long? i really dont want to have to buy new stock bolts for this junker B16A im putting in, anyone kno? TIA
Old Jan 19, 2003 | 06:50 PM
Shawn C's Avatar
In The Garage
Default Re: B18C headbolt ?? (slooowDX)
you cant re-use stock honda headbolts- they are stretch-bolts and it will mess up your engine. get some ARP head studs (non-stretching) or new honda bolts. you will most likely break the used ones if you torque them to oem specs.
Old Jan 19, 2003 | 06:53 PM
slooowDX's Avatar
Default Re: B18C headbolt ?? (22lbGS-R)
i've re-used stock headbolts b4, never had any problems, i understand they stretch, but once or twice should be ok for a pretty much stock engine. anyone else kno if the GSR bolts will work with a B16A block/GSR head or will i need to get some B16A bolts??
Old Jan 19, 2003 | 07:01 PM
Shawn C's Avatar
In The Garage
yes they will work, but i wouldnt use them again. but they are the same bolt
Old Jan 19, 2003 | 07:20 PM
sgT's Avatar
sgT
they are too long. you need b16a/b17a bolts
Old Jan 19, 2003 | 07:25 PM
supercompact's Avatar
Default Re: B18C headbolt ?? (sgT)
The deck height of the GSR block is 6mm taller than the B16a. I think ARP has two different part numbers.
Old Jan 19, 2003 | 07:31 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: B18C headbolt ?? (supercompact)
I was under the impression that the stretch bolts were sort of re-usable, basically for a stock motor and maybe torquing it a few lbs over, but not too much, but that was just soemthign that i heard, is there anyone who can give a 3rd opinion.. just curious..
Old Jan 19, 2003 | 08:29 PM
tnbigdawg's Avatar
Default Re: B18C headbolt ?? (SIXTYdashONE)
Ive reused my b16 bolts on my lsvtec with a couple of foot pounds added to the torque specs.
No problems, and no leaks.
cinder0159
Apr 16, 2011 07:10 PM
The Mole
Dec 6, 2002 06:51 PM
The Mole
Dec 5, 2002 09:29 PM
B16b2b
Sep 9, 2002 09:39 PM
jboostedhatch
May 2, 2001 09:56 PM
