LIghtweight flywheel
Old Jan 19, 2003 | 04:42 PM
cormegga
Guest
Posts: n/a
Default LIghtweight flywheel
Will a 8.8lb flywheel hurt my times at the track. Its a 2nd gen b16 on gsr tranny.
Old Jan 19, 2003 | 05:03 PM
texan's Avatar
Default Re: LIghtweight flywheel (cormegga)
No, it will help. Also, what track is this, a drag strip?
Old Jan 19, 2003 | 05:05 PM
cormegga
Guest
Posts: n/a
Default Re: LIghtweight flywheel (texan)
yeah a drag strip and my best time with stock flywheel 14.6.
Old Jan 19, 2003 | 08:56 PM
TimoneX's Avatar
New User
I wouldn't expect much of a change, but it won't hurt either.
Old Jan 20, 2003 | 01:56 AM
AussieK24's Avatar
Default Re: LIghtweight flywheel (TimoneX)
I'm not a fan of lightened flywheels in all motors at the drags. I think I'll stick with a stock one as I think it helps the car get out of the hole....
Old Jan 20, 2003 | 05:20 AM
TimoneX's Avatar
New User
Default Re: LIghtweight flywheel (b16a4me)
I've never cared for the "you need stored inertia from a heavier flywheel to take off theory", but I won't start another debate on the subject either. I believe there are a few instances when light flywheels don't make sense, like if you have almost no power(under 100 ponies), or if you have massive power, like the nitro burning funny car dragsters, for almost every other application, a lighter rotating assembly is simply more efficient.
Old Jan 20, 2003 | 01:47 PM
cormegga
Guest
Posts: n/a
I got over a 100hp to the wheels and its a chromoly flywheel not any of that factory lightened bullshit.
Old Jan 20, 2003 | 02:25 PM
TimoneX's Avatar
New User
Alum is fine. I use a Fidanza. The strength of the chromoly simply is not necessary for a flywheel, and god save the queen if that thing shatters at high RPMs.
Old Jan 20, 2003 | 05:31 PM
cormegga
Guest
Posts: n/a
Its an xact flywheel by act i dont think it will shatter.
Old Jan 20, 2003 | 06:04 PM
sauceman's Avatar
Default Re: LIghtweight flywheel (zetarider)
10lbs UR Ultra L flywheel on my 95 EX Accord, works great, very good improvement over stock. Your 8.8lbs should only be better.
Old Jan 20, 2003 | 08:09 PM
Lord Helmet's Avatar
Act chromoly streetlite flywheel 12.5lbs
you can get at http://www.nipponpower.com for $250 or less I think?
Old Jan 20, 2003 | 10:04 PM
Volcom's Avatar
That's what new flywheel I'm running right now. I'm still breaking in the clutch but the FW is great. Every gear is more reponsive. The Integra should have come from the factory with this flywheel weight. I don't have any regrets (well, maybe one - should have gone lighter )
Old Jan 20, 2003 | 10:10 PM
TimoneX's Avatar
New User
Default Re: LIghtweight flywheel (Volcom)
You mean like a Fidanza fly?
Old Jan 21, 2003 | 08:48 AM
Volcom's Avatar
Maybe the xACT 8.8 pound flywheel. I don't know if I could have afforded the Fidanza fw. Do you like the FW that light? I was too scared to go too light. Well, now that I have driven it, I wish I wouldn't have been scared. Plus, my dad helped me with the install and he was pissed that I went down to 12.5. He tought that was too light.
Old Jan 21, 2003 | 09:01 AM
TimoneX's Avatar
New User
It was $290 shipped, not exactly a fortune. The lighter the better. I forget exactly what it was but it seems like it was lighter than it was supposed to be when I got it. Cheap scale perhaps it was at fault. 7.6lbs or something of the sort.
Old Jan 21, 2003 | 10:49 AM
Volcom's Avatar
290 shipped isn't bad at all. I think my FW was 240 shipped free.
Old Jan 21, 2003 | 01:27 PM
cormegga
Guest
Posts: n/a
I got mine from clutchcity online 250 and if i dont shift its like the car just gets up. What the number of miles i need to break in my clutch i have 776 that is street and highway miles combined. Is my clutch broken in where i can go to the track its an exedy full face organic racing clutch.
Old Jan 21, 2003 | 02:30 PM
TimoneX's Avatar
New User
Organic clutch discs don't have long break-ins. Kevlar does. If it doesn't work right yet, there may well be something amiss.
Old Jan 21, 2003 | 03:29 PM
cormegga
Guest
Posts: n/a
Feels good a little better than stock. Hey timonex can a final drive out a type r work in a gsr tranny
Old Jan 21, 2003 | 04:24 PM
TimoneX's Avatar
New User
Yep. I believe it's the JDM final drive people scavenge. I've not done this myself, though I'm considering a Type R LSD whilst my tranny is out.
Old Jan 21, 2003 | 06:34 PM
cormegga
Guest
Posts: n/a
COol how much for the lsd
Old Jan 22, 2003 | 08:46 AM
keebler65's Avatar
exedy recommends 500 street miles for the organic discs, so figure out how much of that 776 is street. you're probably ok as long as it wasnt mostly all highway.
Old Jan 22, 2003 | 10:32 AM
TimoneX's Avatar
New User
You can usually pick one up for $250ish, if you're patient and look around. Allot cheaper option than Quaiffe or Kaaz, though not as effective.
Old Jan 22, 2003 | 01:28 PM
cormegga
Guest
Posts: n/a
Default Re: LIghtweight flywheel (keebler65)
about half of it is street.
Old Jan 22, 2003 | 03:20 PM
Malgerus's Avatar
Had my stock one machined down to 12.5 lbs... can't afford one of those expensive aftermarket ones. My brother has the same thing and it revs a little faster, more fun to drive
