does anyone have specs on the D16y8 and the D17vtec EX?
I want valvetrain specs of each car, stroke, bore, and etc, please ....clearances...I'm seeing if what everyone is saying is true...but I think the D17/D16 heads are almost identical...I need every spec possible, and ideas are very welcomed...
thanks again guys...
Jay...
Jay...
What is that the D17a2? I may have to look that one up!
Well here's the little bit I know about these two. Both are SOHC Vtec engines and have a bore of 75mm, the D17 has a stroke of 94.4? and the D16y8 is 90? The D17 has a displacement of 1668cc and the D16 has a displacement of 1590. Power for the D17 is 127bhp@6300 and torque is 114@4400...I think. The D16y8 is 127bhp@6600 & 107ft/lbs@5500. C/R is 9.9:1 & 9.6:1 D17/D16 respectively. I do not know what decks heights are on those 2. Hope this helps.
BTW what is it "everyone" says is true?
Well here's the little bit I know about these two. Both are SOHC Vtec engines and have a bore of 75mm, the D17 has a stroke of 94.4? and the D16y8 is 90? The D17 has a displacement of 1668cc and the D16 has a displacement of 1590. Power for the D17 is 127bhp@6300 and torque is 114@4400...I think. The D16y8 is 127bhp@6600 & 107ft/lbs@5500. C/R is 9.9:1 & 9.6:1 D17/D16 respectively. I do not know what decks heights are on those 2. Hope this helps.BTW what is it "everyone" says is true?
No, I'm trying to mate a D16 head on my friends D17...I want to make sure that it is kosher, so that he can do it, upgrade cams, shafts, and etc...plus maybe p&p...
Just a thought though...
I just plain don't know that much about those particular engines. You might try:
http://www.g1teg.org/main.html
Or other older honda enthusiast sites.
