Is it Dangerous to run tires with different speed ratings?
Old Jan 19, 2003 | 11:31 AM
Kelvin96GSR's Avatar
25 Year Member
Default Is it Dangerous to run tires with different speed ratings?
I destroyed my front tires and want to upgrade just the front as I'm poor.
Would it be dangerous to run S03's in the front (W rated) with crappy Nitto NT-450's (V-rated) in the back?
TIA
Old Jan 19, 2003 | 11:33 AM
10K2HVN's Avatar
Default Re: Is it Dangerous to run tires with different speed ratings? (Kelvin96GSR)
nope..just make sure you dont drive faster then your lowest rated tire..
Old Jan 19, 2003 | 12:09 PM
SpoonFedHatch's Avatar
w-rated is up to 130 right?? if so, just keep it under 130 and you'll be fine bro
Old Jan 19, 2003 | 12:59 PM
25 Year Member
Default Re: Is it Dangerous to run tires with different speed ratings? (SpoonFedHatch)
W is rated for 168
V is rated for 149
I'm afraid that the lower rated tire will have worse adhesion at lower speeds.
Old Jan 19, 2003 | 03:31 PM
Bantam's Avatar
2nd Coolest Person in DFW
yeah, if you put ultra-high performance tires on the front and just performance on the back It shouldnt make that much of a difference, unless you are racing on a track with some real curves. It is true that your "traction bias" will change which could increase oversteer but chances are that it wont matter. Also, if you race in the rain, the rear tires do not have to displace the water as much as the front ones do, so In short, dont worry about it unless it's an autocross car
SlowDriver74
Nov 17, 2011 01:40 PM
tnywy
Sep 15, 2010 08:11 AM
Squad1
Honda Motorcycles
28
May 20, 2007 08:37 PM
granracing
27
Jun 12, 2005 08:52 PM
EH2DX
Jul 18, 2002 04:26 AM
