Dyno Results!!
Old Jan 19, 2003 | 10:43 AM
rainmanEK's Avatar
big strong guy
Default Dyno Results!!
Went to the Dyno this morning, First off i would like to Thank My Dad, Kenji, Glen, The Mole (Chris), Army Green Eg (Steve), Tool Speed, Leo (jdmspecperf.com), Marcus ( heeltoeauto.com), Sarah M. and there many more that have helped me out while I have built My Engine !!
Engine Mods
1996 Gsr Bottom-end All rebuilt with new Everything but rods
Over Sized bore with JDM ITR Pistons
Mugen Head Gasket
New Type R head
Skunk stage 1 cams
Type R IM
S2000 TB (62mm same as R)
Spoon cam gears
JDM DC ITR header
2.5 inch Exhaust (mandrel bent with magnaflow muffler ES style)
No Cat
Kenji Spec ECU (kicks ***)
Apex-i VAFC
BM FPR
AEM ITR Intake
Toda FW
Exedy clutch
JDM ITR tranny
Plus other little stuff..........
When dynoing we ran into problem with The SOHC Fuel pump i was runing, I need a DOHC one being i was leaning out Bad when VTEC kicked in! So I will end up going back with another fuel pump!
The graph shows My last run compared to first run. Look at that mid range gain Just by lowering Vtec and playing with cam gears !
BTW.... I did hit a peak of 199.7 WHP Though I was Way to lean, So I am assuming next visit will Yeild 200WHP
Heres some pics (Check out the Phytons Kenjis packing ) And my dyno Chart along with a Video of a dyno run!
Eric
Video (right click and save)
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D
Old Jan 19, 2003 | 10:46 AM
disordeR's Avatar
Default Re: Dyno Results!! (rainmanEK)
you ran SUPER learn at that one point in your graph. (can't see the RPM's)
nice numbers though. let's see some pics of your whole car.
Old Jan 19, 2003 | 10:53 AM
(__________)'s Avatar
Default Re: Dyno Results!! (disordeR)
good deal, get that fuel pump and you good to go that A/F is everywhere
Old Jan 19, 2003 | 10:56 AM
Mugen Mike's Avatar
Nice numbers
Old Jan 19, 2003 | 11:13 AM
SiBirdie's Avatar
Default Re: Dyno Results!! (MugenMike)
what are your cam gear setting at ?
ALLMOTOR18's Avatar
...nice setup.
Old Jan 19, 2003 | 11:17 AM
rainmanEK's Avatar
big strong guy
Default Re: Dyno Results!! (SiBirdie)
Intake Is At 2 deg. Advanced
Exhaust Is At 4 deg. Advanced
These cams love to be advanced!
They also love to run lean!
My Timing is @ 16 deg. BTDC (perhaps i could have gone to 18 for little more power?)
Eric
Old Jan 19, 2003 | 11:26 AM
obd2gsr's Avatar
great numbers!
Old Jan 19, 2003 | 11:53 AM
Ausmith's Avatar
Great numbers. Car looks very nice.
Old Jan 19, 2003 | 12:06 PM
mgast's Avatar
Default Re: Dyno Results!! (Ausmith)
those are great # good job. who did the tuning because I am thinging of doing the same things and I am just on the other coast and would be curious of If your tuner would want to tune mine? not meaning to hijack your thread great #'s
later
matt
Old Jan 19, 2003 | 12:11 PM
JDM92CX's Avatar
Default Re: Dyno Results!! (mgast)
Old Jan 19, 2003 | 12:14 PM
StinkyTofu's Avatar
Default Re: Dyno Results!! (xJDM88EF9x)
Wow, those are really nice numbers. Can you post the whole graph showing rpm?
Old Jan 19, 2003 | 12:38 PM
owen_the_soyboy's Avatar
Default Re: Dyno Results!! (StinkyTofu)
Old Jan 19, 2003 | 12:51 PM
hybrider's Avatar
Default Re: Dyno Results!! (owen_the_soyboy)
VERY nice
If You Slip You Die's Avatar
Old Jan 19, 2003 | 01:06 PM
Jason kiDD's Avatar
Great numbers. But then again you can get that pretty much with a stock lude with small bolt ons.. Great numbers nonetheless.
Old Jan 19, 2003 | 01:18 PM
Looose_R's Avatar
Default Re: Dyno Results!! (Jason kiDD)
leaner is meaner nice numbers
Old Jan 19, 2003 | 01:45 PM
K1R's Avatar
K1R
great#, nice car
curious about what size JDM ITR pistons you have?
Old Jan 19, 2003 | 01:48 PM
Haunt's Avatar
you ran SUPER lean at that one point in your graph. (can't see the RPM's)
Really lean, but nice numbers...
Old Jan 19, 2003 | 01:50 PM
itr1244's Avatar
Default Re: Dyno Results!! (Haunt)
Why is this in ITR forume??
NICE number though
Old Jan 19, 2003 | 02:08 PM
2FASTDC2's Avatar
Default Re: Dyno Results!! (itr1244)
great #'s
Old Jan 19, 2003 | 02:15 PM
Type-Rare#1248's Avatar
Default Re: Dyno Results!! (2FASTDC2)
Nice!
are skunk stage 1s similar to toda As?
Old Jan 19, 2003 | 02:32 PM
2001TypeR's Avatar
Well he seems to have a gsr engine built with all the itr parts so i guess it can count almost as an itr engine....
Old Jan 19, 2003 | 02:33 PM
GokuSSJ4's Avatar
great #'s
Old Jan 19, 2003 | 02:45 PM
1.8DC2's Avatar
aren't stage 1 cam almost the same as ITR/CTR cams? i didn't think you could get 200whp with that mild of a cam...you kick ***!
