Help quick please- Adjusting rear drums
Old Jan 19, 2003 | 10:26 AM
tylerdurden's Avatar
Default Help quick please- Adjusting rear drums
I just opened up my drum to adjust it and I can't find the adjuster. I was told there was a star shaped adjuster but I can't find anythinng like that. Any help?
Old Jan 19, 2003 | 10:34 AM
Ef Whore's Avatar
Default Re: Help quick please- Adjusting rear drums (tylerdurden)
Haynes manual helped me--the part your looking for is the clevis(star-shaped). If u cant find it your not looking hard enough---it's behind the upper horizontal spring---take a flathead screwdriver and turn the clevis downwards--until there is friction on the drum. Then go inside the car and adjust the ebrake to 6-8 clicks---7 is ideal. Adjusting it low doesnt do a thing.
Old Jan 19, 2003 | 10:56 AM
EG8R's Avatar
Default Re: Help quick please- Adjusting rear drums (Ef *****)
The adjuster is there. It has to be.... Like he said its at the top and just below the brake cylinder....
Old Jan 19, 2003 | 12:49 PM
Default Re: Help quick please- Adjusting rear drums (mr. skelly)
I found it after I cleaned the whole area really well with brake cleaner. I hope I adjusted it correctly. I didn't want it to drag, but I didn't want it to be loose. In the end I had it so it would spin easily with light pressure, but wouldn't keep going once you weren't pushing it (it would keep spinning before I adjusted it). Any tips on making sure its adjusted correctly?
Old Jan 19, 2003 | 01:05 PM
the DR.'s Avatar
a rule of thumb is to adjust it so it has SLIGHT drag, it should spin about 1 1/2 turns before it comes to a stop on its own.
tonymx18
Jun 11, 2015 04:47 PM
kesnut
Dec 31, 2004 04:39 AM
Dave01
Dec 11, 2003 07:29 PM
