the wiring woes continue...
Old Jan 19, 2003 | 08:15 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default the wiring woes continue...
Well ive got a 90 DX that im about to put a 92 LS into. Ive got a man that said hell do a pigtail for me to convert it to mpfi but he doesnt want to do the whole obd0-obd1 conversion. So my question is can i use his pigtail and then buy a obd1 conversion harness and use it too? What else would i have to wire to have it work with the b18a? Is there anything that i would have to add for it to be compatible with the b18a? Thanks.
Sean
Old Jan 19, 2003 | 01:03 PM
sCeRaXn's Avatar
Default Re: the wiring woes continue... (sCeRaXn)
i know that someone has an answer for me...
Sean
Old Jan 19, 2003 | 01:22 PM
skud_dusty's Avatar
you should be able to still use obd0, seeing as the 90-91 integra motors were obd0.
the main problem i see is dpfi-mpfi
good luck
Old Jan 19, 2003 | 03:00 PM
sCeRaXn's Avatar
Default Re: the wiring woes continue... (skud_dusty)
Well the ecu i have is for an ob1 engine and i sorta wanna keep it that way...that way ill have more tuning options in the future after i get boosted. My question is can i use place racings od0-obd1 conversion harness and that guys dpfi-mpfi together and thats it....or will i have to do more wiring for it to be compadible with the 92 LS engine? Thanks.
Sean
Old Jan 19, 2003 | 03:23 PM
skud_dusty's Avatar
that sounds correct, but i'm not sure it will totally work. contact place racing, and see what they think. you might have to totally switch to an Si harness, because that is usually what people use to switch over.
contacting the company would probably be your best bet
Old Jan 19, 2003 | 04:25 PM
vtecrx's Avatar
I am willing to come to high point and do your conversion for you. How far is that from Greenville, SC? I have conversion harnesses for sale and will do your OBD1 and MPFI conversion for you. In about 3 weeks I will have brand spankin new OBD1 plugs and wiring for the conversion harnesses also.
Andy
[Modified by vtecrx, 8:26 PM 1/19/2003]
[Modified by vtecrx, 8:27 PM 1/19/2003]
str84sfed
Apr 17, 2012 01:26 PM
b18bcrx
16
Dec 28, 2004 06:47 PM
crxSoldado
Mar 31, 2004 11:59 AM
sCeRaXn
Jan 19, 2003 04:22 PM
sCeRaXn
Jan 19, 2003 03:01 PM
