My hybrid hatchback with a short videos.
Old Jan 19, 2003 | 03:20 AM
TedR719's Avatar
Default My hybrid hatchback with a short videos.
UPDATED VIDEOS
Alright here are some vidoes you can see!
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D
Video Clip ---> http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D
[Modified by futuresi, 12:29 PM 1/19/2003]
[Modified by futuresi, 12:00 AM 1/20/2003]
Old Jan 19, 2003 | 03:25 AM
TedR719's Avatar
Default Re: My hybrid hatchback with a short videos. (futuresi)
JDM B16 Sir II
AEM CAI ('00 Si)
Apex-i GT Header
Apex-i N1 Exhaust
Test Pipe
Fields VTEC Controller
Exedy Clutch
Solo Short Shifter w/ ES bushings
AEM Pulleys
Fluidyne Radiator
Hondata Gasket
B&M FPR
Skunk2 Coilovers
Tokico HP Shocks
Progress Camber Kit
15' Rota Slipstreams w/ Falken Azenis
Best 1/4 to date: 15.519@88.18 / 2.253 60' @ 5800ft above sea level
[Modified by futuresi, 12:26 PM 1/19/2003]
Old Jan 19, 2003 | 05:37 AM
JoshuaVTEC's Avatar
Nice hatch... got any better vids?
Old Jan 19, 2003 | 06:26 AM
MPower332TI's Avatar
Default Re: My hybrid hatchback with a short videos. (JoshuaVTEC)
Videos suck bro. The car sounds good though.
Old Jan 19, 2003 | 07:28 AM
Timmayeg's Avatar
New User
Default Re: My hybrid hatchback with a short videos. (jDmDxTuRd)
car sounds good, your 1/4 times are a bit slow though for what you have. what track are you running at?, im high in elevation also but still broke 14's with b16a sirII in a 94 coupe with less mods
Old Jan 19, 2003 | 07:50 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: My hybrid hatchback with a short videos. (91ED6Civic)
He's in Colorado if that explains his slow times for you all.
Hellafied highest elevation possible.
Old Jan 19, 2003 | 07:56 AM
sshaikh01's Avatar
dude those vid. are too dark i can only see red lights and hear the sound.
nice car.
Old Jan 19, 2003 | 08:13 AM
Timmayeg's Avatar
New User
Default Re: My hybrid hatchback with a short videos. (B18C5-EH2)
i run in idhao/utah only a few hundred below colorado, but i do understand that high elevation hurts, and no good #'s come out of there
Old Jan 19, 2003 | 08:38 AM
owen_the_soyboy's Avatar
looks great
Old Jan 19, 2003 | 01:49 PM
TedR719's Avatar
Default Re: My hybrid hatchback with a short videos. (owen_the_soyboy)
I will post better video's here later... I just tooks those after I got the camera last night....
91ED6Civic - The elevation up here kills our cars... I had someone say he went down to Utah and almost ran a second faster than up here... even though there was much of a diffrence.
Sea level times would be mid 14's
Old Jan 19, 2003 | 02:01 PM
If You Slip You Die's Avatar
vids are really bad
Old Jan 19, 2003 | 02:16 PM
IdotheSHOCKER's Avatar
Default Re: My hybrid hatchback with a short videos. (lilxjoker)
That N1 doesnt sound raspy eh??
Old Jan 19, 2003 | 02:28 PM
-Whitey-'s Avatar
Default Re: My hybrid hatchback with a short videos. (EGB18hatch)
video sucks car sounds weak i have the exact same setup with out the radiator and a jdm dc sports jdm ceramic header and my car climbs alot faster and has barely any drop in rpm between shifts...maybe your car needs tuning..i think it should climb faster rpm and speed wise
Old Jan 19, 2003 | 02:46 PM
Colton Grundy's Avatar
Default Re: My hybrid hatchback with a short videos. (FF-Panda)
saw youre car this morning looks nice
Old Jan 19, 2003 | 02:53 PM
xJ.SLOTHx's Avatar
nice hatch
Old Jan 19, 2003 | 02:56 PM
mugen76's Avatar
* needs a video lesson bad*
Old Jan 19, 2003 | 02:58 PM
TedR719's Avatar
Default Re: My hybrid hatchback with a short videos. (mugen76)
Old Jan 19, 2003 | 03:03 PM
TedR719's Avatar
Sorry about the bad videos, I just got the digi cam and was just playing around with them...
My car does need tuning bad, I forgot to add that I have a Walbro 255 fuel pump and the B&M regulator does not tune the fuel pressure down...so instead of climbing up fuel pressure when WOT is just stays within the same 1-3 psi (40-43psi) when I do..
I should have CTR cams in her soon as well as dyno tuning!
Old Jan 19, 2003 | 03:07 PM
-Whitey-'s Avatar
yea thats good to hear..it sounds nice and all but like i said it sounds like its wrong..but if your gonna getit dynoed and tuned it should be very nice soon
Old Jan 19, 2003 | 03:12 PM
TedR719's Avatar
Well I found out what is wrong with my car
Well on the way down to the HAI luncheon (local club site for Colorado) my car wasn't acting like it's normal self. I would cut out on the highway making me stop and pull over like 3 times on the way. Well I thought it was just my car running way to rich or maybe the Fields VTEC controller acting funny.
Well on the way home I drove it slow as everyone passed me and grabed a paper clip to pull what codes I might have. Well it look like the light was having an panic attack... because it took me a while to read all the damn blinks!!
Here they go
Code 3 Map Sensor
Code 17 Vehicle Speed Sensor
Code 21 VTEC Solenoid Valve
Code 22 VTEC Oil Pressure Switch
Code 23 Knock Sensor
Code 41 Primary Oxygen Sensor
All this time I've been forcing the car into VTEC with my Fields unit! Looks like I have some work to do and money to save up.
Old Jan 19, 2003 | 03:55 PM
Code 3 Map Sensor
Holy smokes BATMAN thats a lotta codes !!!
Old Jan 19, 2003 | 04:03 PM
B18EG6's Avatar
Here they go
Code 3 Map Sensor
Well, is that a CEL on in the video? I thought I saw a light on in the instrument cluster
Old Jan 19, 2003 | 05:38 PM
delslow94's Avatar
Default Re: My hybrid hatchback with a short videos. (B18EG6)
yea i saw that check light on it too...sounds like u got wiring probs with the vtec controller. i just put in redone p28 thats been chipped and i found out my check probs...some of the solder had broken off and some wires became loose...so check ur wiring. looks good tho good luck bro
Old Jan 19, 2003 | 07:28 PM
TedR719's Avatar
Default Re: My hybrid hatchback with a short videos. (delslow94)
Yeah time to check the wires...
Damn I say well alot...
Old Jan 19, 2003 | 07:42 PM
Kataku2K3's Avatar
That car is really really fast, are you serious that it only has a B16A in there....
[Modified by Kataku2K3, 9:30 AM 1/20/2003]
