Best cam upgrade for N20 car?
Old Jan 19, 2003 | 02:06 AM
TypeR1558's Avatar
New User
Default Best cam upgrade for N20 car?
Im spraying an 80-100 shot DP. I always had JUN III's in mind, but I dont know if those would be the best for a juiced car. What are the best cams out there for juiced R's?
Also.... is a standalone fms really recommended for nitrous? I am thinking about getting that, but i dont know if I really need it. Would it mainly yeild more power, or would it be for reliability.
Thanks
Jon
Old Jan 19, 2003 | 05:39 AM
Sir_Phobos's Avatar
Default Re: Best cam upgrade for N20 car? (TypeR1558)
Zex
Old Jan 19, 2003 | 08:14 AM
boosted3g's Avatar
Default Re: Best cam upgrade for N20 car? (Civic_driver)
i would just stay stock. ITR cams are not bad and since you have nitrous i would jsut put in a little larger shot if you want more power. If you go with a larger cam you will most likely start to loose low end power. If you keep your current cams and then use more nitrous for the top you will keep the large power band.
Old Jan 19, 2003 | 10:31 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Best cam upgrade for N20 car? (boosted3g)
stock ITR nobody makes a better cam than honda!!!
QuestRacingType-R
Feb 12, 2003 07:47 PM
cjames235
Sep 20, 2002 07:47 AM
