help installing suspension
Old Jan 18, 2003 | 10:03 PM
slowpokesi's Avatar
Default help installing suspension
i cant get the damm rear shock off the car, do i have to unbolt the lca in order to get it down?
Old Jan 18, 2003 | 10:07 PM
ricodemus's Avatar
Default Re: help installing suspension (slowpokesi)
We had to because the bolt that holds the bottom of the shock was seized. It's not much more work. The whole assembly should drop right out.
Old Jan 18, 2003 | 10:21 PM
Ef Whore's Avatar
Default Re: help installing suspension (ricodemus)
grab a framing hammer and start smacking **** j/k...BTW once the whole deal is out it'll be easy to get that bolt free.
Old Jan 18, 2003 | 10:33 PM
slowpokesi's Avatar
Default Re: help installing suspension (Ef *****)
i have the shocks unbolted, just couldnt wedget them out, do i have to remove the lca to get it out, the ****** wouldnt budge.
Old Jan 19, 2003 | 07:13 AM
keithv's Avatar
you will need to unbolt one end of the LCA. i think the end that bolts to the trailing arm is easier to remove and put back in...
Old Jan 19, 2003 | 10:26 AM
Ef Whore's Avatar
Default Re: help installing suspension (breaka_1_9)
oh ok I was under the impression that u couldnt get the shock bolt---yeah just remove the lca bolt that connects to the trailing arm like breaka said.
Old Jan 19, 2003 | 11:38 AM
slowpokesi's Avatar
yay i got it thanks a bunch
my **** rides good now
91 b16a swap
93 delsol shocks <-- brand new-->
h&r gsr springs 2" in drop, the ride is the perfect height, my front was sagging like an 1 inch and half now all that is fixed.
tiresias
Oct 31, 2009 09:09 AM
96 EX
38
May 22, 2009 02:18 AM
soodominican
May 11, 2008 11:25 AM
sooo_slow
Nov 4, 2005 06:53 AM
Full Race A6
Aug 5, 2004 11:30 PM
