removing rear bumpers..help please, i did a search but didn't find any thing...
hey i did search over n over but no luck...i need to know how to remove my rear bumpers on a 91 hb....could yaa help me out a fellow h-t member please
if the 91 and 88 bumpers are the same thing to remove, than I can help.
Theres 4 bolts and 4 screws in total. first take out the 2 phillips screws in the wheelwells, they should be right on the edge, facing the back.
then there are 2 bolts inside the trunk/cargo compartment. you'll have to remove the rear panel, its just held on by litle screws. theres one bolt on each side, take them out.
Then theres 2 bolts you have to get from under the car, look under there and there might be litttle plastic covers you have to take off to get to the bolts. once again theres 1 on each side. after you take those out, it should come right off and you just have to disconnect the license plate light wires after u get i off a bit.
good luck
edit: If you get confused or have any questions, just IM me and I'll try to help
[Modified by Hcivic88, 9:00 AM 1/19/2003]
good luck
iphatcrxi
Aug 29, 2006 05:30 PM
