2000 itr suspension into EK9 chassis.
Old Jan 18, 2003 | 06:03 PM
ultradx's Avatar
Default 2000 itr suspension into EK9 chassis.
Hey how yall doing?, my question is ,will a stock 2000 itr suspension will bolt on my 96 civic hatchback or will required extra parts ?
Any input welcome, thanx
Old Jan 18, 2003 | 06:11 PM
SuperTwinz's Avatar
Default Re: 2000 itr suspension into EK9 chassis. (ULTRADX)
Welcome aboard! The lower control arms from a itr will not work on a EK front and rear. I suggest doing a search before posting something like this. https://honda-tech.com/zerosearch Anyways, I started like you before and learned so enjoy...
Old Jan 18, 2003 | 06:15 PM
ultradx's Avatar
Default Re: 2000 itr suspension into EK9 chassis. (Supertwinz)
sup man!, i did check under search, but no luck.
Old Jan 18, 2003 | 07:19 PM
locass316's Avatar
you can use the springs from an itr but you can only use the front shocks because the rear lca wont work with ek. If you want a good oem suspension you can get ctr springs and shocks.
Old Jan 18, 2003 | 07:31 PM
ultradx's Avatar
Default Re: 2000 itr suspension into EK9 chassis. (locass316)
sorry 4 not being specific here, im tryin to do 5 lug conversion form the type r.
Old Jan 18, 2003 | 07:35 PM
whoDAT's Avatar
everything will bolt up to your ek except the rear lca's. the itr's rear struts are ball joint while yours is fork style, also the itr's lca is shorter
[Modified by whoDAT, 8:28 PM 1/20/2003]
Old Jan 21, 2003 | 10:07 AM
ultradx's Avatar
Default Re: 2000 itr suspension into EK9 chassis. (whoDAT)
Bump
Old Jan 21, 2003 | 10:17 AM
Bizarre's Avatar
Isn't an Ek9 a Civic Type R?
Old Jan 21, 2003 | 10:58 AM
ultradx's Avatar
Default Re: 2000 itr suspension into EK9 chassis. (Bizarre)
sorry about that, its a 96 civic hatch from usdm.
Old Jan 21, 2003 | 10:59 AM
ultradx's Avatar
Bump
Dave_yd
Suspension & Brakes
Nov 1, 2008 01:07 PM
JDMstatus95
11
Dec 7, 2007 12:42 PM
lDanny
13
Jun 10, 2004 02:00 PM
rbf351
Jun 20, 2002 12:21 PM
HugoR
Jul 27, 2001 11:15 AM
