ls in a crx
Old Jan 18, 2003 | 02:49 PM
92gsrhatch's Avatar
Default ls in a crx
are there any stock mounts that will fit a ls motor in an 88 crx, just curious i have access to many stock mounts.
Old Jan 18, 2003 | 03:20 PM
poison's Avatar
Default Re: ls in a crx (92gsrhatch)
no.
you will need to get a b series mount kit for ef's.
Old Jan 18, 2003 | 07:55 PM
DirtySohcs's Avatar
if you are good at fabricating and welding you can easlily make some custom mounts with the 90-91 Integra mounts. Ive seen it done before on a couple of cars around here. Or your other option would be to move the factory passenger side mount on the civic's engine bay or weld in two steel plates for that mount position and use the 90-91 Integra mounts, thats what i did on my 89 B16A swap in my civic and had no problems ever. Just depends on your patience and abilities or friends abilities
[Modified by DirtySohcs, 11:56 PM 1/18/2003]
Old Jan 19, 2003 | 01:20 PM
poison's Avatar
Default Re: ls in a crx (DirtySohcs)
yes, but it would not be cost effective unless he can get he OEM mounts for free; then it MIGHT be price comparable for just an aftermarket mount it leaving the engine bay how it is.
waspcrx19
May 22, 2010 08:03 AM
Nova_Dust
Mar 14, 2008 04:40 PM
tallkan
May 6, 2007 11:28 AM
dso
Dec 2, 2004 05:15 PM
89 CRX SI
16
May 1, 2002 09:27 PM
