anyone with a gsr tb on y8 intake manifold???
Old Jan 18, 2003 | 01:49 PM
SPOON_BeIgHtEeNsEe's Avatar
Default anyone with a gsr tb on y8 intake manifold???
im doing a minime swap y7/y8... and where do i plug the iacv at since i cant use the y8 iacv..?
[Modified by SPOON_BeIgHtEeNsEe, 2:29 AM 1/21/2003]
Old Jan 20, 2003 | 05:28 PM
Default Re: anyone with a gsr tb on y8 intake manifold??? (SPOON_BeIgHtEeNsEe)
no 1?
Old Jan 20, 2003 | 05:54 PM
eg6ajk's Avatar
if the manifold is 5spd then just run it in the back as usual otherwise (auto or JDM)will need to have it drilled and tapped.
Old Jan 20, 2003 | 06:36 PM
Default Re: anyone with a gsr tb on y8 intake manifold??? (eg6ajk)
im using the y7 harness and i think the iacv on the y7 is a 2 wire and the y8 is a 3 wire or the other way around... i was suppose to use the y7 tb but decided to go with the gsr tb... and the y7 has the iacv on the tb but the gsr doesnt... so where does the iacv go??? or should i just rewire for the y8 iacv?
Old Jan 21, 2003 | 06:50 AM
eg6ajk's Avatar
y7 = TB mounted IACV and 3 wire
Y8 (5spd) or to use b-series TB = mounted on the intake on the back of it (just like any other OBDI motor), its 2 wire type
freddy chavez
14
May 30, 2013 08:55 PM
uindaway
Nov 12, 2012 01:25 AM
Hondakid95
Engine Management and Tuning
Dec 29, 2011 02:00 PM
pro547
May 11, 2004 04:24 AM
SPOON_BeIgHtEeNsEe
Sep 25, 2003 03:03 PM
