b16 clutch cable bracket
What did u use to get the crx clutch cable to work with the b16 without changing the cable? Did u use the bracket that came on the b16? Did u have to customize it or reposition it? If i turn my bracket upside down, the cable seems to reach, but then there isnt any pressure, at the pedal or the clutch arm. How did u get it to work? IF you have any pics, please post em.
tia
tia
you need to use a crowbar to pull up on the throwout bearing arm on the trans itself. then the cable will be able to reach. do not modify the cable holder, it will only cause more headache in the long run.
But if i turn it upside down, it hold the cable just fine, and it pulls the lever on the tranny itself just fine. basically the cable holder stock looks like this. ----___|.
if it flip it upside down it looks like this. ___----| the bolts will always be on the right side of the picture. the cable routes through the side on the left always. Why wouldnt this work? it makes my cable reach, plus im not prying on the transmission.
Like my illustrations?
90civichbsi
12
Sep 9, 2002 06:41 PM
