which tires should i get
Old Jan 18, 2003 | 09:10 AM
jeddy0120's Avatar
Default which tires should i get
i am looking in to getting new tires for the summer i think that i am going to go with the azenis just because of the price and good performance of the tire.
my regular wheel size is 185/65/15 and the size the have in the azenis is 205/50/15.
so my ? is do u guys think the change in profile and so on will change the rolling diameter of the car, will the change in tire make my speedometer to become off? any recommendations are welcome thanks guys.
Old Jan 18, 2003 | 10:04 AM
SpoonEK2's Avatar
Default Re: which tires should i get (jeddy0120)
To calculate rolling diameter, take 185mm (width of the tire), divide by 25.4 (mm per inch), multiply by .65 (sidewall height is a percentage of width...in this case 65%), multiply by 2 and add 15".
185mm = 7.28in (converting width to inches)
7.28in x .65 = 4.73in (calculating sidewall height)
4.73in x 2 =9.47in (x2...you have 2 sidewalls [top/bottom])
9.47in + 15in = 24.47in (total rolling diamter)
stock = 24.47in
azenis = 23.07in (supposed measurement at 205/50/15)
azenis = 23.66in (actual measurement is closer to 220/50/15)
Your speedo will be off. It will show you going faster than you really are because of shorter effective gearing. But the shorter gearing will give you better acceleration.
Old Jan 18, 2003 | 10:43 AM
all stock's Avatar
Default Re: which tires should i get (SpoonEK2)
how would u be able to adjust the speedometer?
SpeedingHatch
Mar 10, 2006 06:48 AM
GsR-Freak
Apr 14, 2005 04:42 AM
combustion
Nov 6, 2003 07:21 AM
1stealthls
Feb 7, 2003 11:22 AM
Toda
Apr 27, 2002 11:11 PM
